(Refurbished) Wyze Video Doorbell v2
2K porch protection with local microSD storage.
Bundle & Save
![Black Wyze Video Doorbell v2](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-01.png?v=1697752115&width=1445)
![2K video resolution taken of delivery person in front of video doorbell cam](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-02_1a0bab7c-ae88-40cb-af00-197bb855f453.jpg?v=1698163896&width=1445)
![Close-up of hand inserting MicroSD card into built-in slot.](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-03_096a8762-4a27-4c99-a99a-f74fd032f90c.jpg?v=1698163896&width=1445)
![(Refurbished) Wyze Video Doorbell v2](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-03.jpg?v=1708542869&width=1445)
![Delivery person standing in front of doorbell camera as someone speaks through it](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-04_887ebba7-d0b3-43c8-93f9-34440c8c743c.jpg?v=1708542869&width=1445)
![Comparison images of color night vision vs traditional night vision](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-06.jpg?v=1708542869&width=1445)
![Guest arriving at house, waving his hand at the camera, and an overlay of a smart phone notification](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-07.jpg?v=1725658262&width=1445)
![Close-up of hands installing controller for chime support](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-05.jpg?v=1708542869&width=1445)
![Voice deterrence coming from doorbell camera as someone tries to steal package.](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-08.jpg?v=1708542859&width=1445)
![Comparison of pre-roll recording which shows motion leading up to event.](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-09.jpg?v=1708542859&width=1445)
![Doorbell cam covered in water drops and is still working](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-10_55ada746-df95-4614-8f5d-fcf4d12f8c0d.jpg?v=1708542859&width=1445)
![Smart home hub with screen on a nightstand showing livestream of doorbell camera](http://www.wyze.com/cdn/shop/files/WyzeVideoDoorbellv2Main-11_9391d5b0-240a-4151-afef-c902c1bbbefc.jpg?v=1708542859&width=1445)
Enjoy crystal-clear 2K video.
Head-to-toe viewing and immaculate 2K resolution means you can capture all porch arrivals and departures in more detail than ever.
![](http://www.wyze.com/cdn/shop/files/D03F2795E9A5_1687229181_1.jpg?v=1697583644&width=1500)
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-01_e4d26962-09d5-43a3-a1fa-4dd0e671e756.jpg?v=1697740091&width=1500)
24/7 local recording with microSD card.
The first-of-its-kind onboard microSD card slot allows for continuous local recording. So you can stop wondering what happened before or after the doorbell press.
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-02.jpg?v=1697585771&width=1500)
Works with your home's existing chime.
No more bypassing the existing chime when you upgrade to a smart doorbell. A chime controller is included so you can keep ding-donging the old fashioned way.
Learn more with our chime compatibility check.
Two-way talk.
Quickly respond to visitors by pressing the "talk" button in the Wyze app.
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-03_4423fcc0-9625-4e14-b980-053117d75373.jpg?v=1697590154&width=1500)
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-04.jpg?v=1697585959&width=1500)
Nothing says, "Don't try any funny business" quite like an automated voice prompt that alerts visitors they're being recorded. Simply enable this feature in the Wyze app.
Note: Cam Plus or Cam Protect subscription is required for this feature.
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-05_10908d52-225f-4f36-b444-265f47fcd75d.jpg?v=1697737925&width=1500)
Pre-roll motion recording.
The wired power setup enables 3-6 seconds of pre-roll recording for motion events, so you'll capture the scene before the motion starts.
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-10_31b5d84f-e91d-48d9-95a1-63e5e2a4de1b.jpg?v=1725658519&width=1500)
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-06_483125c4-3c1f-44ef-a2e3-1c0eaff0aedf.jpg?v=1697749901&width=1500)
IP65 weatherproof.
Rated to withstand any weather. Especially, the "it's raining packages which means my partner maxed out the AMEX again" type of weather. That's the worst weather.
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-07.jpg?v=1697586027&width=1500)
Night as clear as day.
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-08_939be812-dcd5-4efb-9149-ac762c4c4330.jpg?v=1697740109&width=1500)
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-09.jpg?v=1697740135&width=1500)
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-11.png?v=1697740155&width=1500)
![](http://www.wyze.com/cdn/shop/files/Video_Doorbell_v2_PDP-12.png?v=1697740178&width=1500)
An angled mounting wedge is included with every doorbell to help you achieve the perfect view.
Use preset quick responses to have the doorbell say things like: "Be there shortly" or "Leave the package at the door."
Leave no dong un-dinged.
Here's a fancy pants recap of why Wyze Video Doorbell v2 is the best smart video doorbell around.
