1 of 14
Wyze Scale Ultra
Wyze Scale Ultra
High‑Precision Body Smart Scale
Most 5 Star Reviews
Highly Rated Online
Color
Want a scale that does a full body scan?
$49.98
Use a 5-digit ZIP code.
A black screen with no visible content.
4.3-inch Full Color
TFT Screen
A black background with no visible text or objects.
13 Essential Body
Composition Metrics
Easily Track Data Trends
A black background with a white icon.
Syncs with Popular Health Apps
Step up to an ultra-new way to track your health. Wyze Scale Ultra measures 13 body composition metrics and displays your data on a huge 4.3-inch TFT screen in full color. Connect to Wi-Fi for easy data syncs to your favorite fitness apps, without your phone nearby. Full-surface glass sensors, smart user recognition and long-lasting battery life make this scale a must-have tool for your fitness journey.
    4.3-inch Full Color TFT Screen
    Cutting-edge screen displays your health data in vivid color, no app needed.
    13 Essential Body Composition Metrics
    Measure your weight, body fat percentage, heart rate, BMI, and so much more.
    Track weight, body fat, and other trends directly on the scale and Wyze app.
  • A black background with a white icon.
    Connect with your favorite fitness app: Apple Health, Google Fit, and Fitbit.
Wyze Scale Ultra Specs
Color & Materials
  • Color: Black or White
  • Materials: Plastic, Silicone, ITO Coated Glass
  • Weight: 3.96 lbs / 1.8 kg
  • Dimensions: 11.8 in x 11.8 in x 1.18 in / 300 mm x 300 mm x 30 mm
Power
  • Battery-Powered: 4 x 1.5V AAA Batteries (Included)
Display
  • Display Units: lb/kg
  • 4.3" TFT LCD Screen (see more health insights on the scale)
Weight Range
  • 11 - 400 lbs / 5 - 180 kg
Available Measurements
  • Displayed On Scale: Weight, Body Fat Percentage, Lean Body Mass, BMI, Muscle Mass, Muscle Mass Percentage, Visceral Fat, Basal Metabolic Rate, Bone Mass, Metabolic Age, Protein, Body Water Percentage.
  • Displayed In-App: Weight, Heart Rate, Body Fat Percentage, Lean Body Mass, BMI, Muscle Mass, Muscle Mass Percentage, Visceral Fat, Basal Metabolic Rate, Bone Mass, Metabolic Age, Protein, Body Water Percentage.
Weather
  • Operating Temperature: 41°F-104°F (5°C-40°C)
  • Operating Humidity: 20 - 85% RH
  • Storage Temperature: -4°F-131°F (-20°C-55°C)
  • Storage Humidity: 90% RH
Connectivity & Compatibility
  • Connectivity: Wi-Fi and Bluetooth 5.0®
  • Supported Fitness Apps: Apple Health / Google Health / Health Connect
Warranty
  • 1 year warranty
  • Wyze Scale Ultra x 1
  • 1.5V AAA Batteries x 4
  • Quick Start Guide x 1
No, connecting to the scale is optional. Your measurements will display on the screen, even without Wi-Fi.
Both scales measure 13 body composition metrics, and connect via Bluetooth. However, Wyze Scale Ultra has a huge customizable 4.3-inch TFT screen on its surface. And now with a Wi-Fi connection, you can check your data from anywhere with the Wyze app.
As many as you want! There is no limit to how many Wyze scales you can add to one Wyze account. Put a Wyze Scale Ultra in every bathroom, and in your home gym, too.
Anyone can use Wyze Scale Ultra to take their weight measurement, no matter their age. Body composition (Body Fat %, Water %, etc.) is only available for people between the ages of 10 and 100 years old. Children under 10 and seniors over 100 will not be able to access the body composition features. For users between 10-17, body composition data is only for reference.
Wyze Scale Ultra has a weight range of 11-400 lbs (5-180 kg).
Yes, but it will only measure your weight. To take your other body composition measurements (ex. Body Fat %, Water %) you will need to step on the scale with both feet while barefoot.
No, only use the scale on a hard, flat surface. Carpets and rugs can affect the calibration of your scale, giving you inaccurate measurements.
Only step on Wyze Scale Ultra with dry or slightly damp feet, and only when the surface of the glass is not wet. If wet, wipe down the scale and your feet before stepping on.
Yes, the Wyze app provides a quick and convenient way to measure your heart rate from anywhere in under 10 seconds.
Consult your physician first. By default, Wyze Scale Ultra sends a weak (and safe) electric current through the body for Bioelectrical Impedance Analysis (BIA). There are no known risks with using BIA while pregnant, but body composition results may not be accurate. Set the scale to Pregnancy/Weight-Only Mode to only measure your weight, and disable the BIA measurement entirely.
Home-use smart scales are designed for reference. Wyze Scale Ultra uses bioelectric impedance analysis (BIA) to estimate body composition, particularly body fat. BIA is a popular method to estimate body fat percentage, but there are many other methods available. While a good estimate, the data calculated by your Wyze Scale Ultra may vary from those given by professional-grade medical instruments or methods.
Tap on the surface of the scale to activate it, find the UNIT/RESET button on the back of the scale. Press and hold the button for 3 seconds. The LED display will show “CLr” when the scale is reset.
On the back of Wyze Scale Ultra, locate the bumpy area over the battery compartment. With two thumbs, press downward on the center of the compartment cover, away from the UNIT/RESET button.
4.3 inches of full-color data at the tip of your toes.
A best-in-class TFT screen presents robust health data in vivid color without opening the app. Customize to view what’s important to you.
Wyze digital scale with blue display.
Body Water Percent
Track 13 Essential Health Metrics
Keep track of important health metrics like weight, body fat, muscle mass and more. We haven't figured out how to measure the joy you'll feel when you achieve your dream bod, but we're working on it.
A woman holding a smartphone.
Wi-Fi and Bluetooth Connection
When connected to Wi-Fi your data automatically syncs, so your phone doesn't have to loiter around while you're on the scale.
Man holding a large brown dog.
Baby, Pet & Luggage Mode
We get it. Maths is hard. Weigh your baby, pet, luggage, or your kid’s absurdly heavy backpack with smart baby/pet mode and Wyze Scale does the calculations for you.
Two colorways to fit any room.
Wyze Scale Ultra comes in two neutral color options to compliment whatever vibe you got going on in your porcelain palace.
  • A white scale with a blue display.
  • A black scale with a digital display showing the weight of an object.
1 of 2
Unlimited Sharing & Smart User Recognition
Share it with the whole fam bam. Wyze Scale Ultra automatically recognizes and syncs data for up to 8 unique users. Take one-off measurements for an unlimited number of guests. Share data and trends with an unlimited number of people to stay motivated.
Scale Ultra
Scale Ultra
Works with the brands you love.
No need to ditch your existing fitness tracker. Wyze Scale Ultra connects to top health apps for a smooth syncing and complete control over your wellness journey.
  • A red heart on a black background.
    Apple Health
  • Google Health
  • A blue heart with a blue circle in the middle.
    Health Connect
A black button with a green line pointing to it.
Anti-Slip Floor Contacts
Sturdy construction and grippy rubber floor contacts enable safe and accurate measurements, every time.
Tempered glass electrode coating.
ITO Coated Glass
Step anywhere on the scale. An ITO conductive glass gives highly accurate body composition measurements.
A man lying on a mat with a scale next to him.
Long-Lasting Battery Life
They say nothing lasts forever. Except maybe the embarrassment you feel when the airport barista tells you to have a nice flight, and you say, "You too!" Like, why would you say that? They're not going anywhere. Anyways, enjoy up to 9 months of battery life with this scale.
Compare Scales
Compare Scales
Wyze Scale Ultra measures 13 body composition metrics and displays your weight, BMI, and body fat percentage.
Wyze Scale Ultra
from $49.98
Wyze Scale X is a Bluetooth smart scale that measures 13 body composition metrics and allows up to 8 users.
Wyze Scale X
from $38.98
Wyze Scale S - A digital scale with a green background and the Wyze logo.
Wyze Scale S
from $29.98
BodyScan Handle For Professional Results
# of Electrodes for More Accuracy
TFT Screen
Customizable Display
Wi-Fi Connection
Heart Rate
In App
In App
In App
In App
Trend View
On Screen/In App
On Screen/In App
In App
In App
Weight Range
11-400 lbs
11-400 lbs
11-400 lbs
11-400 lbs
Battery Life (Up To)
8 Months
9 Months
22 Months
18 Months
ITO Conductive Glass
Power Source
4 AAA Batteries
4 AAA Batteries
4 AAA Batteries
3 AAA Batteries
Automatic Bluetooth Connection
Baby/Pet/Luggage Mode
Color
Black/White
Black/White
Black/White
Black/White
Dimensions
15.43 x 13.39 x 2.13 in
11 in x 11 in x 1 in
Only Weight Mode
Athlete Mode
Weight
5.95 lb
3.96 lb
3.96 lb
3.32 lb
View
View
View
View
Support Articles
To set up your Wyze Scale Ultra:
Before starting, insert the batteries into your Wyze Scale Ultra. Then place it on a hard, flat surface and enable Bluetooth on your phone.
  3. Tap Lifestyle > Wyze Scale Ultra.Your phone will search for your scale, pair with it, and connect to it.
  4. Name your device or choose a pre-selected name, then tap Save.You can add this device to your Favorites by leaving the box checked.
  5. Add your details (Year of Birth, Height, etc.).You must be between 10 and 100 years old to get Body Composition data.
  6. Tap Next. Your phone or tablet will pair with your scale again.
  7. Step on the scale to activate it. Make sure your device's BluetoothⓇ is enabled. Your weight will display on your device and Wyze Scale Ultra.
  8. A Setup Wi-Fi popup will appear. Tap Yes.Or tap No to skip. You can set this up later in your scale’s settings.
  9. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.Tap the icon in the password field to display the password to ensure it was entered correctly.
  10. Once Wi-Fi has successfully connected, tap Ok and you’re all set!
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
Download the Quick Start Guide for Wyze Scale Ultra in this article.
Below is the Quick Start Guide for Wyze Scale Ultra, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Scale Ultra including:
  • What's in the box for Wyze Scale Ultra.
  • How to set up Wyze Scale Ultra.
  • Notes on how to use and where to place your Wyze Scale Ultra.
  • How to read the TFT display.
