1 of 8
Wyze Cordless Vacuum S
Affordable, High-Power Cordless Vacuum
Best Selling
Everyone's Top Pick
Add ons
$99.98 $193.99
Use a 5-digit ZIP code.
Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support. Wyze Cordless Vacuum S! If those other vacuums would cut the cord and move out of their parents' basements, maybe they'd know what it was like to live with 20,000 Pa suction power and a 40-minute interchangeable lithium ion battery. Plus, not just one, but two motors, and exactly the same weight as 2.8 pounds of feathers.
  • A black and white icon of a vacuum cleaner.
    100 AW / 20,000 Pa suction power
    Lightweight at 2.8 lbs
  • A black and white icon of a battery with a lightning bolt in the middle.
    40-minute interchangeable lithium-ion battery
  • A computer mouse icon.
    LED screen
Wyze Cordless Vacuum Device Details
Color: Steel grey with Wyze green accents
Dimensions
  • Main unit: 12.4 x 4.5 x 8.7 inches
  • Assembled unit: (main unit + standard tube + floor brush, standing on the floor, measured from the floor to the top): 41.1 in
Weight
  • Main unit: 2.8 lbs
  • Assembled unit (main unit + standard tube + floor brush): 4.9 lbs
Weather Resistance
  • None. For indoor use only.
Battery and Charging
Charging Method
  • AC Charging
Charging input
  • 100-240V~50/60Hz
Charging time
  • 4-6 hours to 100%
Battery type
  • 6 cell lithium ion battery
Battery capacity
  • 2,000mAh*6
Rated voltage
  • DC 21.6 V
Rated power output
  • 300 W
Vacuum Operation
  • Dust cup volume: 0.7 L
  • Noise level: 65 dBA in Turbo Mode
Running time
  • ECO Mode: 40 minutes
  • Medium Mode: 23 minutes
  • Turbo Mode: 10 minutes
Suction power
  • 100 AW, 20,000 PA in Turbo Mode
  • 9,000 PA in Medium Mode
  • 6,000 PA in ECO Mode
Recommended Temperature
  • Operating:-4ºF - 169ºF (-20°C - 75°C)
  • Charging: 32ºF - 113ºF (0ºC - 45ºC)
  • Storage: -4ºF - 77ºF (-20ºC - 25ºC), -4-77F
  • Main Unit (Battery included) x1
  • Charger x1
  • Crevice Tool x1
  • Floor Brush x1
  • Dust cap x1
  • HEPA Filter x1
  • Filter Housing x1
  • Standard Tube x1
  • Quick Start Guide x1
1. Remove the vacuum from the packaging.
2. Fully charge the vacuum using the included charger. The LED screen will show 100% when fully charged. Unplug the vacuum from power.
3. To turn on the vacuum and operate in Medium Mode (default), press the Power button and begin cleaning. For change the suction, tap the Mode Shift button on the LED screen to switch to Turbo Mode or Eco Mode.
4. To turn off the vacuum, press the Power button again.
The cordless vacuum performs best when used indoors, on dry surfaces, bare floors, and carpets with short and firm textures. It is not recommended to use Wyze Cordless Vacuum S on thick or plush carpets. You can switch to handheld use by attaching the accessories after removing the floor brush and aluminum tube.
Use attachments to clean areas like your sofa, bed, ceiling, and stairs.
Note: The cordless vacuum only comes with a Crevice Tool and the 2-in-1 Brush tool. You can purchase additional attachments at Wyze.com.
The capacity of the dust cup is 0.55 L.
The volume is about <80 dBA in Turbo Mode, the strongest mode.
Use the crevice tool to pick up crumbs and dirt in corners, nook, and hard-to-reach areas.
Yes, Wyze Cordless Vacuum S works great to remove pet hair from all dry surfaces.
No, only use Wyze Cordless Vacuum S on dry surfaces to pick up dry debris. Do not use it on wet surfaces or to pick up liquids.
Liquids, including water and oil.
Chemicals, inflammable and explosive hazardous materials.
Sharp objects such as broken glass, construction waste, screws, etc.
Burning objects such as cigarette butts, matches, and ash.
Pet waste.
Remove the dust cup from the Main Unit, pull out the HEPA filter, and rinse the filter and dust cup with fresh water. Let all parts air dry completely. Do not expose the filters to direct sunlight or high temperatures.
More detailed maintenance instructions are available in the Quick Start Guide.
No, it cannot stand up on its own.
No, it does not.
When it comes to suction power, motors matter most
Cheap motors yield cheaper results. We went all-out with a beefy digital motor that reaches an industrial level of suction. Our efficient, brushless design significntly reduces friction to maintain peak power, high durability, and longer battery life.
A close up of a cordless vacuum with a blue light.
Not just one motor. TWO motors.
We added another motor in the brush head because we’re as serious about cleaning as you are about picking up every strand of Fido’s majestic mane.
A black vacuum cleaner with blue lights on a wooden table.
Close up image of cordless vacuum battery screen.
The right power for every surface
Different surfaces call for different levels of suction. Select between 3 different cleaning speeds. Monitor speeds, and monitor your usage with a crystal-clear LED display.
Eco 6,000 Pa
Med 9,000 Pa
Turbo 20,000 Pa
A close up of a cordless vacuum battery.
Long-lasting, interchangeable batteries
Finish what you started. Enjoy up to 40-minutes of fade-free power that lasts until the job is done.
Ready or not, dust can’t hide
Dust bunnies have been living rent-free in the shadows for too long. See more with 6 daylight-bright LED lights in the brush head to illuminate dust and debris under furniture.
A vacuum cleaner with green lights on. A cordless vacuum with green LED lights on the bottom.
With LED
Without LED
A cordless vacuum with a 3-stage filtration system.
First, the vacuum cyclone separates different sized debris. Next, a metal screen filters large particles like dirt and hair. Finally, a high-efficiency HEPA filter removes 95% of particles <0.3 µm in diameter.
A person is using a vacuum to clean a counter.
A person is holding a green and blue filter in a kitchen sink.
A close up of a vacuum cleaner with a filter brush.
More to love
Use one finger to release and empty the dust cup.
The dust cup and filters are simple to remove, rinse, and reuse.
Rotate the built-in filter brush to knock dust off your filter into the dust cup and maintain maximum efficiency.
Support Articles
Download the Quick Start Guide for Wyze Cordless Vacuum S in this article.
Attached is the Quick Start Guide for Wyze Cordless Vacuum S, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Cordless Vacuum including:
  • The components of Wyze Cordless Vacuum S.
  • How to assemble your Wyze Cordless Vacuum S.
  • How to charge and maintain Wyze Cordless Vacuum S.
  • How to clean Wyze Cordless Vacuum S.
During regular maintenance, the motorized brush should also be cleaned to reduce the chance of clogging.
  1. Remove any attachments by pressing the release key.
  2. Press the brush release button, then pull to remove the brush.
  3. Run a razor blade down the groove to break up any hair or debris as necessary, then clean any that remain.
  4. Slide the brush back into the housing until it clicks back into place.
Changing the HEPA filter can be done in a few quick steps:
  1. Press the green button at the front of the handguard to release the dust bin.
  2. Remove the dust bin, and pull the HEPA filter out from the top.
  3. From underneath the dust bin, twist the filter housing counter-clockwise, then pull to remove it.
  4. Clean the filter housing by tapping it over a trash can to remove larger debris, then rinsing it with clean water.
  5. Reinsert the filter housing and twist clockwise to secure it.
  6. Place the HEPA filter back in the top of the housing (or replace with a new one as necessary), pressing firmly to make sure it’s seated.
  7. Place the dust bin back onto the motor housing, making sure it snaps back into place against the handguard.
Note: The HEPA filter can also be rinsed with water, but needs to be dried completely before being reinstalled.
Emptying the Wyze Cordless Vacuum is designed to be easier and more mess-free to empty than the competition.
To Empty your Dust Bin:
  1. Hold the dust bin over a trash can.
  2. Press the release button located in the handguard near the power button.
  3. Once empty, snap the dust cover back in place.
