Wyze Video Doorbell v2
2K porch protection with local microSD storage.
Bundle & Save
Enjoy crystal-clear 2K video.
Head-to-toe viewing and immaculate 2K resolution means you can capture all porch arrivals and departures in more detail than ever.
24/7 local recording with microSD card.
The first-of-its-kind onboard microSD card slot allows for continuous local recording. So you can stop wondering what happened before or after the doorbell press.
Works with your home's existing chime.
No more bypassing the existing chime when you upgrade to a smart doorbell. A chime controller is included so you can keep ding-donging the old fashioned way.
Learn more with our chime compatibility check.
Two-way talk.
Quickly respond to visitors by pressing the "talk" button in the Wyze app.
Nothing says, "Don't try any funny business" quite like an automated voice prompt that alerts visitors they're being recorded. Simply enable this feature in the Wyze app.
Note: Cam Plus or Cam Protect subscription is required for this feature.
Pre-roll motion recording.
The wired power setup enables 3-6 seconds of pre-roll recording for motion events, so you'll capture the scene before the motion starts.
IP65 weatherproof.
Rated to withstand any weather. Especially, the "it's raining packages which means my partner maxed out the AMEX again" type of weather. That's the worst weather.
Night as clear as day.
An angled mounting wedge is included with every doorbell to help you achieve the perfect view.
Use preset quick responses to have the doorbell say things like: "Be there shortly" or "Leave the package at the door."
Leave no dong un-dinged.
Here's a fancy pants recap of why Wyze Video Doorbell v2 is the best smart video doorbell around.
