1 of 17
Wyze Scale BodyScan
Wyze Scale BodyScan
Our Most Affordable 8-Electrode BIA Scale
Color
$79.98 $84.98
Use a 5-digit ZIP code.
Meet your body's most affordable accountant. Wyze Scale BodyScan delivers professional-grade, dual-frequency 8-electrode BIA with segmental muscle and fat analysis across your arms, legs, and torso. 17 body composition metrics, 7 on the 4.7-inch LED display the second you step on, no app required. Syncs to Apple Health, Health Connect, and Fitbit. Recognizes up to 8 users automatically. 9-month battery life. No subscription. No excuses.
  • Professional-Grade Precision at Home
    Built-in handle and electrodes to measure your arms, legs, and torso individually.
  • Large Information Display
    Cutting-edge screen displays your health data right at your toes, no app needed.
  • 17 Essential Body Composition Metrics
    Measure your weight, body fat percentage, heart rate, BMI, and so much more.
  • Detailed Advanced Reports
    Get a detailed breakdown of your body composition, and track progress trends over time.
Wyze Scale BodyScan Specs
Color & Materials
  • Color: Black or White
  • Materials: Plastic, Silicone, ITO Coated Glass
  • Weight: 4.18 lbs / 1.90 kg
  • Dimensions: 11.81 in x 13 in x 1.49 in / 300 mm × 330.2 mm × 37.8 mm
Power
  • Battery-Powered: 4 x 1.5V AAA Batteries (Included)
Display
  • Display Units: lb/kg
Weight Range
  • 11 - 400 lbs / 5 - 180 kg
Available Measurements
  • Displayed On Scale: Weight, Body Fat Percentage, BMI, Muscle Mass Percentage, Bone Mass, Protein, Body Water Percentage
  • Displayed In-App: Weight, Body Mass Index, Body Fat Percent, Muscle Mass, Muscle Rate, Body Water, Physical Age, Protein, Lean Weight, Bone Mass, Visceral Fat, Basal Metabolism, Subcutaneous Fat, Fat Mass, Skeletal Muscle Mass, Segmented Muscle Mass & Body Fat
Weather
  • Operating Temperature: 41°F-104°F (5°C-40°C)
  • Operating Humidity: 20 - 85% RH
  • Storage Temperature: -4°F-131°F (-20°C-55°C)
  • Storage Humidity: 90% RH
Connectivity & Compatibility
  • Connectivity: Bluetooth 5.0®
  • Phone Compatibility: Android 10.0+, iOS 16.0+
  • Supported Fitness Apps: Apple Health, Health Connect, Fitbit
Warranty
  • 1 year warranty
  • Wyze Scale BodyScan x 1
  • 1.5V AAA Batteries x 4
  • Quick Start Guide x 1
Both scales use the same dual-frequency eight-electrode body impedance analysis (BIA) with a handle for segmental body composition analysis, and both measure the same 17 body composition metrics, so you're getting the same professional-level measurement accuracy with either scale. Wyze Scale BodyScan shows 7 key metrics on its LED display and delivers your full segmental breakdown, detailed reports, and trend tracking through the Wyze app. Wyze Scale Ultra BodyScan adds a customizable TFT screen for viewing more metrics and segmental data directly on the scale, plus Wi-Fi connectivity for automatic syncing. If you want the same accuracy at an unbeatable price, BodyScan delivers it for less.
Both scales connect via Bluetooth and track body composition metrics through the Wyze app. Wyze Scale BodyScan steps it up with dual-frequency eight-electrode BIA and a handle that measures body impedance in your arms, legs, and torso individually, delivering results that are more accurate and personalized than the 4-electrode foot-only measurement used by Wyze Scale X. BodyScan also features a large 4.7-inch LED display showing 7 key metrics on-screen and includes 17 body composition metrics with segmental muscle mass data. If you're serious about understanding your body composition beyond just weight, BodyScan is well worth the upgrade.
As many as you want! There is no limit to how many Wyze scales you can add to one Wyze account. Put a Wyze Scale BodyScan in every bathroom, and in your home gym, too.
Anyone can use Wyze Scale BodyScan to take their weight measurement, no matter their age. Body composition (Body Fat %, Water %, etc.) is only available for people between the ages of 10 and 100 years old. Children under 10 and seniors over 100 will not be able to access body composition features. For users between 10-17, body composition data is only for reference.
Wyze Scale BodyScan has a weight range of 11-400 lbs (5-180 kg).
Yes, but it will only measure your weight. To take your full body composition measurements (ex. Body Fat %, Water %, Lean Body Mass) you must hold the handle and step on the scale with both feet while barefoot.
No, only use the scale on a hard, flat surface. Carpets and rugs can affect the calibration of your scale, giving you inaccurate measurements.
Only step on Wyze Scale BodyScan with dry or slightly damp feet, and only when the surface of the glass is not wet. If wet, wipe down the scale and your feet before stepping on.
Yes, the Wyze app provides a quick and convenient way to measure your heart rate from anywhere in under 10 seconds.
Consult your physician first. By default, Wyze Scale BodyScan sends a weak (and safe) electric current through the body for Bioelectrical Impedance Analysis (BIA). There are no known risks with using BIA while pregnant, but body composition results may not be accurate. Set the scale to Pregnancy / Weight-Only Mode to only measure your weight.
Home-use smart scales are designed for reference. Wyze Scale BodyScan uses bioelectric impedance analysis (BIA) to estimate body composition, particularly body fat. BIA is a popular method to estimate body fat percentage, but there are many other methods available.
While a good estimate, the data calculated by your Wyze Scale BodyScan may vary from those given by professional-grade medical instruments or methods.
Open the battery compartment, then set the scale down. Tap to activate the scale, then press and hold the UNIT button above the batteries. The TFT display will show “Clear” when the scale is reset.
On the back of Wyze Scale BodyScan, locate the arrow over the battery compartment. With two thumbs, press downward on the center of the compartment cover, away from the UNIT/RESET button.
BodyScan precision. Somehow even more affordable.
A deeper scan from head to toe.
8 smart electrodes across your hands and feet to measure your arms, legs, and torso individually, delivering gym-grade body composition insights without the gym membership.
Ultra-detailed data reports. No subscriptions.
Get segmental data for your arms, legs, and torso without paying an arm and a leg.
4.7 inches of phone-free data without the scrolling.
View 7 key metrics instantly on the massive 4.7-inch LED display. The app's there when you want to go deeper, but you don't need it to know where you stand.
Track 17 Essential Health Metrics
Keep track of important health metrics like weight, body fat, muscle mass and more. We haven't figured out how to measure the joy you'll feel when you achieve your dream bod, but we're working on it.
Track Body Metric Data Trends
View insightful body metric trends instantlyon the scale every time you step on it.
Baby, Pet & Luggage Mode
We get it. Math is hard. Weigh your baby, pet, luggage, or your kid’s absurdly heavy backpack with smart baby/pet mode and let us do the calculations for you.
Unlimited Sharing & Smart User Recognition
Share it with the whole family. Wyze Scale BodyScan automatically recognizes and syncs data for up to 8 unique users. Take one-off measurements for an unlimited number of guests. Stay motivated by sharing data and trends with an unlimited number of people.
Reliable Bluetooth® Connection
Quickly sync your health data to the Wyze app and track your metric history.
Two Colorways to Fit Any Room
Wyze Scale BodyScan comes in two color options to match whatever vibe you've got going on in your porcelain palace.
Works with the brands you love.
No need to ditch your existing fitness tracker. Wyze Scale BodyScan connects seamlessly to your health apps for smooth syncing and complete control over your wellness journey.
  • A red heart on a black background.
    Apple Health
  • A blue circle with a white dot in the center.
    Fitbit
  • A blue heart with a blue circle in the middle.
    Health Connect
Anti-Slip Floor Contacts
Sturdy construction and grippy silicone floor contacts enable safe and accurate measurements, every time.
ITO Coated Glass
Step anywhere on the scale. An ITO conductive glass gives highly accurate body composition measurements.
Long-Lasting Battery Life
They say nothing lasts forever. Except maybe the embarrassment you feel when the server tells you to have a nice meal, and you say, "You too!" Like, why would you say that? Anyways, enjoy up to 9 months of battery life with this scale.
Compare Scales
Compare Scales
Wyze Scale BodyScan is a professional-grade.
Wyze Scale BodyScan
from $79.98 $84.98
Wyze Scale Ultra measures 13 body composition metrics and displays your weight, BMI, and body fat percentage.
Wyze Scale Ultra
from $49.98
Wyze Scale X is a Bluetooth smart scale that measures 13 body composition metrics and allows up to 8 users.
Wyze Scale X
from $38.98
Wyze Scale S - A digital scale with a green background and the Wyze logo.
Wyze Scale S
from $29.98
BodyScan Handle For Professional Results
# of Electrodes for More Accuracy
TFT Screen
Customizable Display
Wi-Fi Connection
Heart Rate
In App
In App
In App
In App
In App
Trend View
On Screen/In App
On Screen/In App
On Screen/In App
In App
In App
Weight Range
11-400 lbs
11-400 lbs
11-400 lbs
11-400 lbs
11-400 lbs
Battery Life (Up To)
9 Months
8 Months
9 Months
22 Months
18 Months
ITO Conductive Glass
Power Source
4 AAA Batteries
4 AAA Batteries
4 AAA Batteries
4 AAA Batteries
3 AAA Batteries
Automatic Bluetooth Connection
Baby/Pet/Luggage Mode
Color
Black/White
Black/White
Black/White
Black/White
Black/White
Dimensions
11.8 in x 13 in x 1.5 in
15.43 x 13.39 x 2.13 in
11.8 in x 11.8 in x 1.18 in
11 in x 11 in x 1 in
Only Weight Mode
Athlete Mode
Apple Health / Fitbit / Health Connect
Weight
5.95 lb
5.95 lb
3.96 lb
3.96 lb
3.32 lb
View
View
View
View
View
Support Articles
To set up your Wyze Scale BodyScan:
Before starting, insert the batteries into your Wyze Scale BodyScan. Then place it on a hard, flat surface and enable Bluetooth on your phone.
  3. Tap Lifestyle > Wyze Scale BodyScan.The app will search and pair with your Wyze Scale BodyScan.
  4. Step on the scale to activate it quickly, so it can connect with your Wyze app.
  5. Name your device or choose a pre-selected name, then tap Save.
  6. Add your details (Year of Birth, Height, etc.), tap Next.You must be between 10 and 100 years old to get Body Composition data.
  7. You're all set! Enjoy your new scale.
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
Problem
The detailed report for your Wyze Scale BodyScan will not populate, even though it populated in the past, or the report disappears.
Troubleshooting
  1. Confirm that your Wyze app is up to date.In your Wyze app, navigate to the Account tab > tap About.Your current app version will be listed beneath the Wyze logo.Compare your app version to the latest app version listed on our Release Notes & Firmware page.If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale BodyScan’s firmware is up to date.You can check this by going to the Account tab > Firmware Update.If there is an update available for the scale, please move forward with updating it.
  3. Ensure the correct user profile is selected in the Wyze app while measuring.
  4. Make sure Body Segments are enabled.In the Wyze app, go to Wyze Scale BodyScan's settings.Ensure Body Segments is enabled.
  5. Attempt to measure again, ensuring that measuring is done correctly.The scale should be placed on a hard, flat surface.Feet must be barefoot.Excessively dry or damp feet may result in incorrect or no measurements. Knees should not be touching.Grip the handle with all fingers, with thumbs placed on the sensor area.Keep arms at a 30°–45° angle while holding the handle.Remain on the scale until measuring is complete.
  6. Power cycle Wyze Scale BodyScan.Remove the batteries for 10 seconds, then reinstall them.
  7. Factory reset Wyze Scale BodyScan, then try the update again.On the back of the scale in the battery compartment, find the UNIT button.Press and hold it for 5 seconds until the LED display shows "Clr".Set up the scale as new.
Note: We do not recommend having multiple versions of Wyze Scales on a single Wyze account, as measuring with different scales may disrupt the report.
