1 of 7
Wyze Video Doorbell (Wired)
Check out the newer model:
  • 2K QHD w/Color Night Vision.
  • Built-in microSD storage.
  • Works with Existing Doorbell Chime.
  • Enables 3-6 seconds of pre-roll recording for motion events.
  • You'll also continue to get the amazing features of Doorbell v1 (wired): 2-way audio and traditional night vision.
Get Doorbell v2
Style
$29.99
Item is no longer available.
Small has never been mightier. Head-to-toe, 1080p, full HD viewing on this wired doorbell camera.
    1080p full HD
    Live stream & recording.
  • A black and white image of a phone being held.
    4:3 Aspect Ratio
    Get the full picture. See people head to toe.
  • Wyze switchicon.
    Two-way Audio
    When someone approaches your door, just open the app to begin talking.
  • A blue and purple circle with a white cross in the middle.
    See more with Cam Plus
    Cloud video storage and advanced AI detections (with subscription).
Wyze Video Doorbell Specs
Color & Materials
  • White
  • Plastic
Dimensions
  • 1.5'' x 3.25'' x 0.625''
Video & Image
  • Image Sensor: 2K (2048 x 1536)
  • Camera: F2.0 aperture, 2.7mm focal length, 1/2.8" CMOS
  • Image Quality: 1080p and 480p w/ 8x Digital Zoom
  • Frames per Second: 20 Daytime, 15 Nighttime
Audio
  • Audio: Built in Speaker & Microphone (with 2-way Audio & Noise/Echo Cancellation)
Additional Details
  • White LED (Fill Light): 6 x 5000K (daylight color temperature)
  • IR Night Light: 4 x 940nm Infrared LED
  • Connectivity: Direct to WiFi 802.11 b/g/n, 2.4GHz (5GHz WiFi not supported)
  • Sub1G: 906.8MHz, used for local connection between doorbell and chime.
  • IP65 Weather-resistant
  • Storage Temperature: -40 to 176°F (-40 to 80°C)
  • Operating Temperature: -4 to 122°F (-20 to 50°C)
  • Field of View: 120° Vertical x 88° Horizontal
Connectivity & Compatibility
  • 2.4 GHz WiFi
Data Security
  • End-to-end encryption, HTTPS secure transfer protocol, AES 128-bit encryption
Wyze Chime
  • Chime Power: Standard US Power Outlet: 100V-240V, 0.1A, 50/60Hz
  • Weight: 2.0 oz / 56g
  • Size: 2'' x 2'' x 1.4''
  • Chimes: 5 modern, 4 classic doorbell, 3 animal sounds, 6 automation sounds, 1 intruder alarm
Wyze Video Doorbell
  • Wyze Video Doorbell x1
  • Wall Plate x1
  • Wedge (Horizontal, 30°) x1
  • Wire Caps x4
  • Bracket Screws x2
  • Screws & Expansion Tubes x2
  • Extension Wires x2
  • Jump Wire x1
  • Quick Start Guide x1
Wyze Video Doorbell + Chime
Everything listed under Wyze Video Doorbell, plus:
No, it is a hardwired doorbell.
Wyze Video Doorbell does not use batteries. It is hardwired, connecting directly with your existing mechanical chime power source.
No, your existing chime won't work.
The existing chime will be bypassed so that the power can be used for your Wyze Video Doorbell.
No, it only detects motion.
Your Wyze Video Doorbell can detect motion and people and has been optimized with a white LED light to ensure you see a clear face in the live stream. It does not detect sound.
Yes, in your doorbell settings.
To change your Wyze Chime volume:
  1. In the Wyze app, tap on your Wyze Video Doorbell.
  2. Tap on the Settings icon on the top right.
  3. Tap Extended Devices > Chime > Tunes.
Yes, Wyze Video Doorbell is IP65 rated as weather-resistant. This means that it is "dust-tight" and protected against water sprays from any angle.
No. Wyze Video Doorbell connects directly to WiFi. It does not connect to the Bridge or the Wyze Base Station.
Yes, absolutely.
Yes! We've integrated with the most popular smart home systems. Use your Amazon Echo smart speakers as doorbell chimes hear the bell ring from anywhere in your house. With Wyze Video Doorbell, you can also view live video feeds of people at the door from your Echo Show and Google Home devices.
Cam Plus allows you to see a live feed of anyone at the door, whether they're knocking or just standing around outside. This makes it easy for you to track who's coming and going without ever having to leave your comfort zone or worry while being away from home.
Yes, but not all functions will work.
Once your Wyze Video Doorbell is paired with Wyze Chime, it will chime when the doorbell is pressed, even if the doorbell is not connected to WiFi.
However, the doorbell will not record event videos to the cloud or send push notifications to your phone if it is offline.
No. Wyze Video Doorbell does not support a microSD card. All recorded events will be stored in the cloud.
Wyze 4.3.
People are taller than they are wide. So is our live stream.
Wyze Video Doorbell records and live streams video in 1080p Full HD with a 4:3 aspect ratio so you can see every visitor from head to toe. You’ll also be able to see packages left on the ground beneath your doorbell.
See it in action
We built a device that allows you to be at your front door no matter where you are. See how Wyze users are using theirs to capture everything from important deliveries to epic snowfalls.
doorbell image size illustration
Size matters. And we’re as small as it gets.
Slim Profile
Keep your curb appeal and let your door stay the center of attention with our slick, compact design.
A dog looking through a window.
Don't worry about visitors missing it.
A motion-activated LED will grab their attention as soon as they approach.
* Photo from a Wyze user
A person holding a cell phone with a picture of a man wearing a yellow hat.
Never miss another visitor. Unless you want to.
Instant Notifications
Receive instant push notifications when Wyze Video Doorbell is pressed so you know the moment someone’s at your door.
Pull up a live stream of your visitor before responding to decide whether you’d like to ignore a solicitor or answer the delivery driver.
Hello, Bonjour, or Hola. Wherever you are, answer your door from miles away.
Two-way audio. Never feel away from home again with two-way audio. When someone approaches your door, just open the app to begin talking.
A man is holding a box with a smile on his face.
Google screen device on night stand.
Integrated with Alexa and Google.
Use your Amazon Echo smart speakers as extra doorbell chimes throughout your home. Command live video feeds to appear on your Echo Show and Google Home devices, even get an alert from Alexa if a person is detected at your door, with Cam Plus.
A white speaker with a green top.
Hear your doorbell ring, chirp, or bark from any room.
Pair any number of wireless Wyze Chimes with your doorbell so every room in your house is ready to alert you when someone’s at the door.
Chime sold separately.
Choose from 19 different chime sounds including traditional bells to birds chirping.
A man wearing a hoodie is holding a box with a doorbell in it.
Beware of Doorbell
Smart Alerts & Video Recording
Wyze Video Doorbell lights up brightly when motion is detected nearby, alerting visitors and would-be porch pirates of your video doorbell.
Plus, you can turn on push notifications to get a phone alert whenever anyone or anything approaches your door, even if they don't ring the doorbell.
Camplus logo with a purple background.
And we created ways for making your cam even smarter
Plan Sold Separately
  • Person Detection
  • Full-length motion recording
  • Vehicle, pet, and package detection
  • See everything that happens at your doorstep
A white doorbell with a blue button on it.
Built to endure the elements.
IP65 weather resistant
Install Wyze Video Doorbell on your door without worrying about interference from the elements. IP65 weather resistance protects this doorbell from rain, snow, and sun.
A blue cell phone with a picture of a porch on it.
Let guests in remotely with Wyze Lock.
Better with Wyze Lock. Don’t worry if the dinner party shows up before you. Let your friends inside when you’re stuck in traffic by remotely unlocking your door with Wyze Lock. Requires: Wyze Lock
Learn More
Surprisingly super simple self-installation. Seriously.
Easy installation. Replace your existing hardwired doorbell in under 20 minutes with our easy DIY installation guide. Check out the video below to see for yourself.
