1 of 7
Wyze Window Cam Wedge Mount
Top Accessory
Commonly Bundled Item
Style
$14.98
Use a 5-digit ZIP code.
Easily Mount
Inside Window
Easy Peasy Install
  • 20° Camera Tilt Angle
  • Secure Adhesive Mounting
  • Reduced Glare and Reflections
  • Easily Mount Inside Window
  • Compatible Wyze Products: Wyze Window Cam
  • Dimensions: 6.37 x 3.99 x 0.92 in (162 x 101.5 x 23.5 mm)
  • Model: WYZEWCWM
  • Weight: 50g
  • Material: Plastic
  • Tilt Angle: 20°
  • Temperatures Operating Temperature: 32°F - 104°F (0°C - 40°C)
  • Storage Temperature: -4°F - 158°F (-20°C - 70°C)
20° View Angle Tilt
Place Wyze Window Cam in your second floor window without missing any events down on the ground.
  • Tilted Down
    Need to mount it on the second floor? No problem. Angle it down to catch all the action down on the ground.
  • Tilted Up
    Place it in a basement window tilted up to catch everything happening outside and uphill.
  • Tilted Left/Right
    Monitor your front porch or look towards the side of you house with a tilted view either left or right.
Once you stick it, it stays stuck. Never worry about it falling off your window.
Specialized Design to Reduce Glare
A specialized angled design removes reflections to give you the clearest footage possible through a window.
Just peel, stick, and plug in the camera. We've included an extra-long 10 ft power cable with cable clips for tidy mounting.
Support Articles
To install Wyze Window Cam Wedge Mount:
  1. Go to your mounting location. Thoroughly clean and dry the inside of the window where you plan to mount your camera. Install on window glass only. Do not mount on a window behind a screen.
  2. Peel off the film from the wedge mount. Do not trim the mounting sticker.
  3. Affix the wedge mount onto the window. Stick the mounting sticker horizontally to minimize glare and for the best image quality.
  4. Remove the plastic from the camera lens, then press the camera onto the wedge mount.
  5. Route the camera’s power cable along the windowsill and/or wall with the included cable clips.
To minimize glare.
The larger sticker is designed to minimize glare caused by indoor lighting reflecting behind your Wyze Window Cam. So not trim the sticker.
For best results, always mount the sticker horizontally.
