1 of 7
(Refurbished) Wyze Wi-Fi 6E Mesh Router Pro
Maximum speed Wi-Fi for every corner.
$35.99 $173.99
12-month extended warranty
Get a 12-month extended warranty when you buy refurbished products on wyze.com. Also get special bundles, unique promos, + rewards with each order
Wyze Refurbished logo
This is a Wyze refurbished product. What does that mean? It's a like new Wyze product, fully tested and guaranteed to work — now at an even better price. Final sale, but a wyze decision.
Wyze Wi-Fi 6E Mesh Router Pro delivers top-of-the-line features and components with class-leading performance. Internet speeds up to 2.5 Gbps with the latest Wi-Fi 6E technology, and access to the new, uncongested 6 GHz band. 75+ devices and 2000 square feet per router for customizable coverage that puts dead spots in their graves. Plus simple setup, wired backhaul, and parental controls. Wyze Mesh Router Pro is Wi-Fi at its Wi-Finest.
  • Wi-Fi 6E logo.
    Wi-Fi 6E/Tri-Band
    Unlock an uncongested 6GHz band.
  • A black background with a white speedometer icon.
    2.5 Gbps Internet Speeds
  • Three connected devices icons.
    75+ Connected Devices per Router
  • A black house icon.
    2,000 Sq Ft of Coverage per Router
Wyze Mesh Router Pro Details
Color: Black
Finish: Matte
Wi-Fi Bandwidth: AXE5400
Coverage: Up to 2,000 sq. ft. each
Devices Supported: 75+ each
Technology: Wi-Fi 6E (802.11ax with 6 GHz support); Wi-Fi 6 (802.11ax); Wi-Fi 5 (802.11ac); Wi-Fi 4 (802.11n); 802.11a; 802.11g; 802.11b; 802.15.4
CPU: ARM Cortex A53 Dual-Core 1 GHz
Flash: 128MB SPI NAND Flash
RAM: DDR3L 1 GB
Radio Configuration (per mesh node): 2.4 GHz (ax 2x2) + 5 GHz (ax 2x2) + 6 GHz (ax 2x2)
Antennas (per mesh node): 6
Frequency: 2.4 GHz, 5 GHz, 6 GHz
Channel Width: 20 MHz, 40 MHz, 80 MHz, 160 MHz
Wi-Fi Data Rate: 802.11ax (2.4 GHz): 288 Mbps x 2 = 576 Mbps; 802.11ax (5 GHz): 1200 Mbps x 2 = 2400 Mbps; 802.11ax (6 GHz): 1200 Mbps x 2 = 2400 Mbps
Hardware Accelerator: Dedicated Wi-Fi Accelerator; Dedicated Routing Performance Accelerator
Ports: 1 x 2.5 Gbps WAN; 1 x 1 Gbps LAN; 1 x USB 2.0 Type A; 1 x DC; 1 x Reset Button
Provisioning Technology: Bluetooth® Low Energy 5.1
Wireless Security: WPA3-PSK (Personal Mode); WPA2-PSK (AES); WPA-PSK (AES)
Power: DC 12V 2A
Temperature Rating: 32°F ~ 104°F (0°C ~ 40°C)
Humidity: Up to 90% RH, Non-condensing
Certifications: FCC, IC
Operation Modes: Router Mode; Bridge Mode (Auto ISP Router Passthrough); Auto WAN/LAN Port Sensing
1-Pack
  • Wyze Mesh Router Pro x1
  • 3' Category 6 Ethernet Cable x1
  • Power Adapter x1
  • Quick Start Guide x1
Pictured: Wyze Mesh Router Pro 1-Pack
2-Pack
  • Wyze Mesh Router Pro x2
  • Power Adapter x2
Coverage area, bandwidth, internet speed supported, and number of devices supported are the main differences between the two. Check out the table above for more details.
You’ll need:
1) Active internet service from your local ISP.
2) An existing modem.
3) A smartphone with active mobile data service for setup.
The best place to put the router is in a central location, away from large appliances, and with good “line of sight” visibility to the main areas of your home.
In theory, you can add as many Mesh Routers to your network as you'd like. But we recommend no more than 10 mesh routers on the same network.
It depends on how much area you need to cover! But here’s a tip: One Wyze Mesh Router System (2-Pack) can cover up to 3,000 square feet while a Wyze Mesh Router Pro System (2-Pack) can cover up to 4,000 square feet.
No, you cannot mix and match different mesh routers on the same network. For optimal coverage, capacity, and performance, choose only one type to install.
Yes, though we recommend you replace your old router with a new Wyze Mesh Router. In some cases, your ISP may provide an all-in-one router and modem combo that cannot be replaced.
No, because Wi-Fi 6 is backwards compatible to older Wi-Fi standards. This means your older devices will still work.
Yes, thanks to Wyze Intelligent Mesh, the mesh router automatically optimizes the backhaul path regardless of if it's a wired or Wi-Fi connection.
Yes, Wi-Fi 6 (IEEE802.11ax) works with legacy standards as follows:
• IEEE802.11b — Wi-Fi 1 (2.4 GHz)
• IEEE802.11a — Wi-Fi 2 (5 GHz)
• IEEE802.11g — Wi-Fi 3 (2.4 GHz)
• IEEE802.11n — Wi-Fi 4 (2.4 GHz & 5 GHz)
• IEEE802.11ac — Wi-Fi 5 (5 GHz)
Experience Wi-Fi at its Wi-Finest
Animation illustrating the different speeds between the three bands, with 6 GHz being the fastest.
Unleash 6 GHz
Wyze Wi-Fi 6E Mesh Router Pro unlocks the hyper-fast, next-generation speed of the new, uncongested 6 GHz band.
That means 5400 total Mbps of system bandwidth and up to 1.2 Gbps to a single device—faster than wired gigabit!
A Wyze device is sitting on a table next to a clock.
Premium today. Premium tomorrow.
Smooth, best-in-class Wi-Fi performance, both now and into the future, as 6 GHz increasingly becomes the band of choice for future devices.
It's your router's fault!
Wyze Wi-Fi 6E Mesh Router Pro is the premium solution to a problem as old as the internet: crummy routers and coldhearted providers.
Watch the video to learn why the traditional model stinks.
Fast doesn't mean what you think it means.
Internet speed is more than just "How fast?" In today's smart homes, "How many?" is just as important. Each Wyze Mesh Router Pro can keep 75+ devices at top speed, all at once, with no waiting in line.
Is your router built to manage today's smart home?
Yesterday's routers can only handle so many devices at once. The rest wait their turn. Wyze Wi-Fi 6E Mesh Router Pro is built for today's smart home and can support multiple devices, all at once.
Wyze Mesh Router Pro can cover homes of all shapes and sizes.
A comparison chart between Wyze's Mesh Routers and their coverage.
A comparison chart shows two different options for a product.
A smartphone screen displaying a network statistics dashboard.
A smartphone screen displaying a list of connected devices.
A phone screen with a guest network option.
Complete network control in the Wyze app
Get daily status reports, right in the Wyze app. And quickly assess the health of your network, including the status of each router and the status/identity of each connected device.
Know exactly which devices are connected to your network and how they're connected. Group them, name them, and manage their access.
Easily create, manage, and share a guest network.
Wondering which mesh router is best for you?
Here's a quick rundown.
A comparison chart between dual-band and tri-band routers.
Wi-Fi setup has never been so easy.
Watch the video to learn, step by step, how to set up your router. Or let the Wyze app walk you through the plug-and-play process.
Premium, whole-home internet has never been easier.
