1 of 7
(Refurbished) Wyze Sprinkler Controller
Smarter. Simpler. Greener.
8-Zone WiFi sprinkler controller + 1 Year of Sprinkler Plus Weather Service.
$24.99 $58.98
12-month extended warranty
Get a 12-month extended warranty when you buy refurbished products on wyze.com. Also get special bundles, unique promos, + rewards with each order
Wyze Refurbished logo
Smarter, simpler, and greener control over your lawn's irrigation system with smart zoned control over your sprinklers.
  • A black background with a white calendar icon.
    Personalized schedules for routines
  • Wyze Sprinkler Icon 3
    Customizable irrigation zones
    Set up to 8 different zones.
  • Easy control from an App
  • Wyze Sprinkler Icon 1
    Unlock weather-based watering with Sprinkler Plus
Products with the WaterSense label are 20% more water efficient than average products in the irrigation control category. You might also receive a rebate on the cost of Wyze Sprinkler Controller in certain districts. https://lookforwatersense.epa.gov/rebates/
Wyze Sprinkler is compatible with most residential irrigation systems in North America. It supports up to 8 zones and can be used with systems that have a master valve or pump relay. It is not weatherproof, so it should only be mounted indoors. It is also not compatible with systems that use index valves.
Sprinkler Plus is an optional service that adds a ton of smarts to your Wyze Sprinkler! With Sprinkler Plus, your Wyze Sprinkler gains advanced weather data that can be used to create Smart Schedules, enable Weather Skips, and provide detailed Zone Moisture information. One year of Sprinkler Plus comes with your purchase and can be renewed annually for $9.99. We plan to continue to add new features and benefits to Sprinkler Plus so stay tuned!
With Sprinkler Plus, you can create Smart Schedules to automatically water your plants when needed. To do this, we use the previous and forecasted weather to calculate the water balance in each zone. When the balance gets to the allowed depletion, we schedule a watering.
If you lose connection to the Internet, Wyze Sprinkler will continue to operate on the saved schedule for the next 14 days. After that, the device falls back to your offline schedule.
No, Wyze Sprinkler requires power to operate your irrigation system.
Wyze Sprinkler is only compatible with up to 8 zones. Do not attempt to put multiple wires into one terminal or daisy chain devices. However, two controllers can work independently, but you must label the zone-to-controller mapping on your own.
No, not at this time. We will consider applying for certification in the future.
Most users can set up Wyze Sprinkler in just 20 minutes.
None at this time, but we will consider adding additional services in the future.
Yes! You are able to limit watering to specific days of the week or even/odd days.
Wyze Sprinkler works with most normally closed rain & soil sensors. See a full list here.
Control your sprinkler remotely.
No more watering the grass when it rains and no more manual timers. Wyze Sprinkler Controller is designed to provide a convenient and affordable way for you to control the watering of your lawn or garden from anywhere with Wi-Fi.
A person holding a smartphone with the Wyze app open to sprinkler settings.
  • "Affordably priced smart sprinkler controller"
    -DigitalTrends
  • "Wyze Sprinkler Controller is a good value"
    -Wirecutter
  • "#1 Affordable Smart Sprinkler Controller"
    -ZDNet
1 of 3
A person holding a leaf with a watering schedule overlay.
Personalized schedules for your weekly routine.
Customize a watering schedule that is most convenient for your busy life. Easily start or stop a watering schedule with just a tap in the Wyze app.
A phone screen displaying a weather app with customizable zones.
8 customizable irrigation zones.
Customize schedules for up to 8 different irrigation zones. Set unique names and photos for each watering zone in the Wyze app so you know which zone is which.
Wyze Outdoor Cam v2 mounted on fence.
Peace of mind with Wyze Cam.
Curious if the dog is using your lawn watering as a slip-and-slide? View live footage of your waterings quickly in the Wyze app and get notified when your system is running.
A black device with a blue light that says "Wyze" on it.
Smarter for the planet.
Wyze Sprinkler Controller earned the coveted WaterSense certification from the EPA for using weather-based watering schedules with Sprinkler Plus.
If every landscape in the United States with an automatic irrigation system installed and properly operated a WaterSense labeled weather-based irrigation controller, we could save 220 billion gallons of water and $2.9 billion in water costs across the country annually from not overwatering lawns and landscapes.
Unlock weather-based watering with Sprinkler Plus.
Water when your plants are thirsty, not when it's raining with Sprinkler Plus. (free 1 year subscription included with the purchase of Wyze Sprinkler Controller)
Upcoming rain, no watering needed for the next three days.
Advanced insights into your yard screen.
Advanced insights into your yard.
With Sprinkler Plus, you can see the historical, current, and future moisture levels for each watering zone. Even view the upcoming weather forecast and watering activities right from the app.
A weather app on a phone displaying a 5-day forecast.
Intelligent weather skips.
Sprinkler Plus can skip unnecessary scheduled waterings based on hyper-localized weather data to save you water and protect your plants.
DIY Installation in 20 minutes.
Wyze Sprinkler replaces your existing controller in less than 20 minutes and automatically creates a schedule for you after setup.
Support Articles
Before you begin set up:
An existing irrigation system is required to use Wyze Sprinkler Controller - it is not a standalone device. Installation and setup should take about 30 minutes.
CAUTION : In order to avoid potential damage from ELECTRICAL INTERFERENCE, pump relays should be installed at least 15 FEET away from Wyze Sprinkler Controller.
What's in the box?
  • Wyze Sprinkler Controller
  • Wall Plate
  • Mounting Screws x2
  • Drywall Anchor x2
  • 24V 1A Power Supply
  • Wire Labels
  • Velcro Cable Wraps x2
  • Sprinkler Plus Coupon
Required Tools
  • A power drill with a Phillips head and 7/32 drill bit
  • Hammer
CAUTION: In order to avoid potential damage from ELECTRICAL INTERFERENCE, pump relays should be installed at least 15 FEET away from Wyze Sprinkler Controller.
Remove your existing controller
Before you get started, disconnect the power to your existing sprinkler controller.
  3. Tap Home > Wyze Sprinkler.
  4. Tap Begin Mounting. Check the box next to "I've unplugged the power to my existing controller".
  5. Tap Begin.
  6. Take a photo of the wires going into your existing controller. You may have to remove the cover to expose the wires. This photo will be helpful if you require additional troubleshooting.
  7. In the Wyze app, select the terminals that have wires going into them on your old controller. See wires that aren't listed in the app? Please see: I don't see all my terminals
  8. Once you've selected the wires, use the included stickers to label each wire.
  9. Finally, disconnect the labeled wires and remove your old controller from the wall. If your old controller is in a box, you may need to remove it.
Install the mounting plate
The first step is to hold the mounting plate in the desired location. It's important you check that both the new power adapter and your existing wires will reach the new mounting location.
  1. Hold the mounting plate to the wall and use a pen to mark the holes.
  2. Use a 7/32 drill bit to pre-drill the holes.
  3. Then, insert the wall anchors, gently hammering them into place.
  4. Hold the mounting plate back up to the wall and screw the plate into position.
    Be sure that the Wyze logo is right-side up.
Connect your Wyze Sprinkler
  1. Insert each labeled wire to the corresponding terminal on Wyze Sprinkler The two C terminals are the same so you can insert your C-Wire to either one.You will need to press down on the terminal lever to insert the wire.
  2. Once inserted, make sure the wires are fully inserted and stay in place when gently tugged.
  3. Plug Wyze Sprinkler into an outlet using the included adapter
  4. Wait for the numbers on the front of the device to start cycling in orange.
Your device is now ready to be paired to the Wyze app, after it's mounted.
Mount your Wyze Sprinkler
Place the top of the device into the mounting plate and then firmly push the bottom into place.
You should hear a snap as it locks into place. You can also use the included cord wraps to neatly tie all your zone cords together.
Pairing to the Wyze app
  1. The numbers on the Wyze Sprinkler should be cycling in orange, it's in pairing mode. Don't see this? Make sure the Wyze Sprinkler is plugged into power, then press the reset button on the back.
  2. Follow the in-app instructions to complete pairing.
Once the device is paired to the Wyze app, you will be asked to set up your zones.
Activating Sprinkler Plus
Each new Wyze Sprinkler Controller comes with 1 year of Sprinkler Plus. To redeem your prepaid year, simply scan the QR code on the card in the box with your phone and follow the on-screen instructions to complete activation.
If you have previously used the code and want to re-activate it, go to services.wyze.com.
Download the Quick Start Guide for Wyze Sprinkler here.
Below is the Quick Start Guide for Wyze Sprinkler, a short manual on how to get started.
This guide is a short user manual with the basics about Wyze Sprinkler, including:
  • What's in the box for Wyze Sprinkler.
  • Basic operation of Wyze Sprinkler.
  • Frequently asked questions for Wyze Sprinkler.
Wyze Sprinkler replaces the controller of your existing irrigation system. Refer to the Compatibility Guide below to see if your system will work with Wyze Sprinkler.
Additional Note:
Wyze Sprinkler is not a standalone device, is not an irrigation system, and it cannot be used as a timer that attaches directly to a hose. It works similarly to how Wyze Thermostat replaces your existing thermostat, and how Wyze Video Doorbell replaces your existing wired doorbell.
