1 of 26
Battery Video Doorbell + Palm Lock
Secure your front porch without a cord in sight.
$158.98 $195.96
Use a 5-digit ZIP code.
Wyze Video Doorbell:
  • Head-to-Toe Viewing
  • 1536 x 1536 HD+ Resolution
  • Wire-Free or Wired
  • Up to 6-Month Battery Life
  • AI-Powered Person & Package Detection
  • Easy Install in Minutes
Wyze Palm Lock:
  • Contactless entry with palm vein recognition.
  • Numbered keypad with access codes.
  • Control from anywhere with Wi-Fi.
  • Up to 6 months of battery life.
  • Manual lock and key option.
  • Peace of mind with auto lock.
  • Head-to-tow View Angle
    Wide 150° x 150° view angle sees visitors and packages tucked right against your door.
  • 1536 x 1536 HD+ Video Resolution
    Records and streams crystal clear video with a 1:1 aspect ratio.
  • 6-Month Battery Life
    Get up to 6 months of battery life, or hardwire for continuous power.​
    Place it anywhere (mounting hardware included). A corner plate is also included for optimal viewing angles.
  • A black image of a palm vein.
    Touchless Palm Scan Unlock
    Just hover your palm near the reader and the door unlocks using highly secure, contactless biometric tech.
  • A black screen with a white logo and text reading "Wifi Control".
    6 Entry Methods + Wi-Fi Control
    Unlock with your palm, code, keys, app, voice-assistant or latch. Control from anywhere with Wi-Fi.
    No Down Time with Dual Battery System
    The main battery provides 6-months of charge. The backup keeps things running while you recharge.
  • A black and white image of a hammer and wrench.
    Replaces Existing Deadbolt
    Includes a manual lock and key option (set of keys included).
Wyze Battery Video Doorbell Specs
Colors & Materials
  • Model: MR_BVD
  • Finish: Gloss
  • Color: Black
Dimensions
  • 5.71 in x 1.85 in x 1.14 in (145 mm x 47 mm x 29 mm)
Weight
  • 7.58 oz (215 g)
Camera and Microphone
  • Field of View: 150° x 150°
  • Resolution: 1536 x 1536
  • IR Lights: 850nm
  • Siren: 90dB
Wyze Palm Lock Specs
Colors & Materials
  • Model: WPLCK1
  • Finish: Matte
  • Color: Black
  • Materials - Frame: Aluminum Alloy and Steel
  • Materials - Panel: Tempered Glass
Dimensions
  • External Assembly: 6.14 x 2.89 x 1.28 in (156 x 73.5 x 32.5 mm)
  • Internal Assembly: 7.16in x 2.93in x 1.18in (182mm x 74.5mm x 30mm)
Weight
  • 4 lbs (64 oz)
Power
  • Power Source: Rechargeable 6400 mAH battery or 5V/2A DC/12-24V, 50/60HZ AC Wired
  • Battery Life: Up to 6 months with normal use
  • Charging Port: USB-C port (USB-C cable included)
Local Storage
  • MicroSD Card: Up to 256 GB
Weather & Operating Temps
  • Weather Resistance: IP65
Operating Temperature
  • -4°F - 122°F (-20°C - 50°C)
Storage Temperature
  • -4°F - 140°F (-20°C - 60°C)
Certifications
  • FCC, IC, UL, DOE, CEC, NRcan, CA65, TSCA
Connectivity & Compatibility
  • Communication Method: Bluetooth® 5.0, 2.4 GHz Wi-Fi, Wi-Fi 6
  • Compatibility: Wyze app 3.7+, Android 10.0+ or iOS 16.0+
Warranty
  • 1-Year
Wyze Palm Lock:
  • 1x Wyze Palm Lock
  • 1 x Exterior Assembly
  • 1 x Interior Assembly
  • 1x Mounting Plate
  • 1x Deadbolt
  • 1x Strike Plate
  • 1x Dust Box
  • 1x Main Battery
  • 1x Backup Battery
  • 1x Silicone Plug
  • 1x Drilling Template
  • 1x Quick Start Guide
  • 2x Mechanical Keys
  • 4x Wood Screws
  • 3x Interior Panel Screws
  • 4x Mounting Screws
Wyze Battery Video Doorbell:
  • 1x Wyze Battery Video Doorbell
  • 1x Corner Back Plate
  • 1x Flat Back Plate
  • 3x Wire Nuts
  • 1x Jump Wire
  • 3x Long Screws
  • 1x USB-C Charging Cable
  • 2x Extension Wires
  • 3x Expansion Tubes
  • 1x Doorbell Detaching Pin
  • 3x Quick Start Guide
A battery-powered doorbell built to see the full picture.
Experience effortless front porch protection, no matter where you live. Easily install it wired or wire-free and view it all from anywhere in crystal-clear HD+ resolution.
Wide head-to-toe view angle.
See more of what matters. With a 150° horizontal and 150° vertical field of view, Wyze Doorbell captures everything from a visitor’s smile to a package tucked against your door.
Keep an eye on kids coming home from school, delivery drop-offs, or unexpected guests, all without blind spots. Even if someone stands close to the camera, you’ll still see the full picture — from head to toe, porch to street.
Wire-free or wired.
Go up to 6 months on a single charge, or hook it up to your existing doorbell wiring for nonstop power. Recharging is easy, just plug into the USB-C port on the back.
A black device with a blue light on it.
Flexible chime options.
Never miss a ring. Connect to your home’s existing chime, or pair with a Wyze Universal Wi-Fi Chime (sold separately) to hear alerts anywhere in your home, even through your Wyze Cams.
Pick from 20 chime sounds and 8 volume levels to match your style (or have a little fun and set it to a dog bark to surprise uninvited guests).
Easy to install for homes and apartments.
Mount anywhere with the included hardware and corner plate for the perfect view. Ideal for renters or homeowners who want simple, secure installation without hassle.
When motion is detected, Wyze Battery Video Doorbell can automatically play a “You are currently being recorded” message, letting visitors know they’re on camera.
That simple phrase can make a big difference. Studies have shown that visible or audible signs of surveillance reduce break-ins by up to 60%, and most burglars admit they’ll avoid homes with cameras or alarms altogether.
A Battery Video Doorbell with a Palm Lock.
With two-way audio, you can greet guests, give delivery instructions, or let friends know you’ll be right there, all through the Wyze app.
In a rush? Use Quick Responses to instantly play preset messages like “Please leave the package at the door” or “Be there shortly.” Perfect for when your hands are full, your baby’s napping, or you just don’t feel like yelling through the door.
Battery Video Doorbell with Palm Lock, providing a secure front porch without a cord in sight.
IP65 weather resistance.
No need to worry about water damage, foggy lenses, or failed recordings of those cheaper doorbells. Get reliable protection and peace of mind, no matter what the forecast says.
The key is the palm of your hand.
Highly secure, contactless biometric tech identifies you based on the unique pattern of veins beneath the surface of your palm. Just hover your palm near the reader, and voilà, the door unlocks. It’s like a secret handshake with your front door.
A smartphone displaying a lock screen with the message "Access and Sharing" and a button to unlock the Wyze Palm Lock.
A bright, numbered keypad illuminates with a simple tap. Set and store up to 50 unique access codes, or create one-time guest passcodes that expire on a schedule.
A black device with a white label that says "Wyze Palm Lock.
No down time.
Wyze Palm Lock uses a dual-battery system, so there isn't any down time. The main battery provides up to 6 months of battery life, and the backup battery keeps things running for up to two weeks while you charge the main.
A built-in gyroscope detects the angle and movement of the door in real time. Once it senses the door has closed then it automatically locks, preventing false or jammed locks.
A smart lock that can be controlled via a smartphone app.
A black and green lock with the number 15493 on it.
Featuring anti-peep technology.
With anti-peep technology, you don't have to worry if someone watches you enter your code.
Simply add extra digits before or after your code and Wyze Palm Lock will still unlock.
A person is holding a key to a Wyze Palm Lock.
Discreet manual lock and key option.
Still yearning for the comfort of a traditional key? We got you covered. Simply slide down the damping cover and manually unlock the old-fashioned way (set of keys included).
Hey Luke, who's your deadbolt daddy?
OK, maybe don't ask him that. Instead, see what this modern day Skywalker had to say when we asked him about Wyze Palm Lock.
A smartphone screen displays a Wyze Palm Lock.
Works with Wyze video doorbells.
Lock and unlock directly from the live view of your Wyze video doorbell without switching between screens to open the door for family and friends.
A black and wet Wyze Palm Lock Shopify 13.
IP53 weather-resistant & BHMA3 certified.
Backed by the Builders Hardware Manufacturers Association, this lock has been tested, slammed, twisted, and splashed thousands of times to make sure it can handle real life. It meets rigorous standards for security, durability, and performance. It’s not just smart, it’s strong.
BHMA Logo
Watch and learn. It's super easy to install.
Wyze Palm Lock is compatible with almost all exterior doors and replaces your existing deadbolt lock in about 20 minutes. Watch our unboxing and install demo below.
