1 of 6
(Refurbished) Wyze Robot Vacuum
Room mapping. Path planning. Efficient cleaning.
Model
Low stock: 32 left
Wyze Refurbished logo
This is a Wyze refurbished product. What does that mean? It's a like new Wyze product, fully tested and guaranteed to work — now at an even better price. Final sale, but a wyze decision.
"I wouldn't be surprised if it becomes one of the best-selling robot vacuums around."
Vacuum Wars is the undisputed leader of vacuum reviews on YouTube. We didn’t ask them to do this, but here’s their in-depth review of the Wyze Robot Vacuum.
Robot Vacuum mapping out house
Precise Room Mapping with LIDAR.
Unlike other vacuums that smash head first into furniture and crash into walls, Wyze Robot Vacuum uses an invisible spinning laser (LIDAR) to build an exact map of your home. You can see, edit, and save the map in the Wyze app.
Robot vacuum house map
Straight-line cleaning path.
Using the map built by the LIDAR sensor, the Wyze Robot Vacuum divides each room into sections and cleans in the most efficient path possible.
7 Sensor Groups to See All Directions at Once
Specialized sensor groups help the vacuum move around obstacles and detect stairs and walls.
Underneath wyze robot vacuum
wyze robot vacuum
Superior design. No dirt left behind.
The edge-brush sweeps debris towards the center of the vacuum. A high-torque center brush works in tandem with 2100 Pa of suction power to pull up every bit of dust and dirt off your floor.
Person telling Alexa to ask Wyze Robot Vacuum to start cleaning
Works with Alexa.
Don't want to move a finger? Just say "Hey Alexa, tell Wyze Robot Vacuum to clean the kitchen."
All Wheel Drive for Uneven Surfaces.
Wyze Robot Vacuum cleans all types of surfaces—hard flooring or soft carpet. It can cross heights up to 0.8 in (20mm) to clean across any bumps in the road.
wyze robot vacuum moving from a carpet to tile floor
Automatically Returns to Recharge.
Wyze Robot Vacuum drives itself back to the charging station after it's finished cleaning. If battery runs low during a longer cleaning, it returns right back to where it left off after auto-recharging.
wyze robot vacuum returning to its charging station
Average Battery Time (110 Minutes Standard Mode)
