1 of 13
Amazing sound. At your command.
Bundle
$97.99 $139.97
30-day returns for new unopened items.
Fill the room with gorgeous sound featuring crisp highs and rich bass on the Google Nest Audio speaker. With built-in Google Assistant, voice controls make it easy to play songs from streaming services, get help around the house, and more. Plus, Nest Audio adapts to your environment so whatever you're listening to instantly sounds better, whether it's music or podcasts.
Negotiated by Wyze
The products featured on Negotiated by Wyze do not always integrate with Wyze devices or the Wyze app. However, the Google Nest Audio does.
These products are manufactured by unaffiliated companies but are shipped by Wyze. Wyze may receive a commission, at no additional cost to you. The devices are not eligible for Wyze's Return Policy and Limited Warranty Terms. However, products damaged in transit will be replaced by Wyze. Please reach out to our support team in this situation. For product-specific assistance and warranty claims, please reach out directly to the manufacturer.
Show more +
  • A black background with a white fingerprint icon.
    Respects your privacy
    Dim the lights
  • A single white light bulb shining in a black background.
    Enhance your audio experience
  • A hand holding a phone.
    Connect to Wyze
Nest Audio
  • Color: Chalk
  • Dims: 6.89 in x 4.89 in x 3.07 in
  • Power cable: 59 in (1.5 m)
  • Device weight: 2.65 lbs (1.2 kg ) (without external power adapter)
Power
  • External adapter: 30W, 24V
  • DC power jack
Speakers & Mics
  • 75 mm woofer and 19 mm tweeter
  • 3 far-field microphones
  • 2-stage mic mute switch (hardware mute)
Sensors
  • Capacitive touch controls (3 touch areas)
Connectivity
  • 802.11b/g/n/ac (2.4 GHz/5 GHz) Wi-Fi
  • Bluetooth® 5.0
  • Chromecast built in
Technology
  • Google Assistant built in
  • Voice Match technology
  • Google Nest Audio x 1
  • Power adapter and cable x 1
  • Documentation bundle x 1
Bundles will include a single unit of the bundled Wyze device.
Experience room-filling sound.
Wyze x Nest Audio
Control your Wyze smart home in-app or with the power of your voice.
"Hey Google, turn on my Wyze Bulb Color"
"Hey Google, turn on Christmas lights"
"Hey Google, dim Family Room Bulb by 50%"
A white speaker with a Google logo on it.
Designed with Privacy in mind.
Disable the microphone using the discreet mic switch on the back of your speaker.
How about data privacy? You're in luck, you can easily erase your Google Assistant history at your convenience.
Add the Nest Audio to your Google Hub for the full experience.
Pair with other Nest speakers or other Google products for amazing sound and a modern smart home experience in every room.
  • Rich, full sound.
    With Nest Audio's woofer, tweeter, and tuning software, crisp vocals and powerful bass fill your room.
  • Clear audio.
    Nest Audio adapts to your environment and whatever you're listing to, so music sounds better. And news and podcasts sound even clearer.
A close up of a speaker with a sound hole.
*Subscriptions may be required. Sound improvements as compared to the original Google Home.
  • Room-filling sound, times two.
    Paid two Nest Audio speakers for stereo sound. Group them for amazing sound across multiple rooms. Or move music from room to room.
  • Audio quality that packs a punch
    .75” twitter, 3” woofer. Great for music. Even better for dinging when someone rings your Wyze Doorbell v2 and Duo Cam Doorbell.
  • Entertainment in any room. And every room.
    Play music on Nest Audio. Or throw on a soothing lullaby at night for your kids.
A smart assistant device that works with Google and Amazon.
Home assistance without lifting a finger.
Tell Google to spin play your favorite tunes or show a Wyze Camera live stream, adjust the volume, and more. All that with just your voice.
An ecosystem that works together.
Your individual Wyze devices are awesome. As a team, the possibilities are endless. A light switch that unlocks the door. A lock that flips on the lights. The best part is our devices play well with the Google Nest Hub and Nest Mini too.
Image wall room with Wyze Cam v3, Wyze Thermostat, Wyze Switch, Wyze Video Doorbell, Wyze Floodlight and Wyze Lock
A white camera on a wall.
