1 of 15
Apartment Plus Kit
Apartment Plus Kit
Best Value
The Most for Your Money
Add ons
$132.98 $155.94
Use a 5-digit ZIP code.
IP65 Weather Resistant
2.5K QHD Color Night Vision
2 Way Audio
Battery-powered or Hardwired
Upgrade your apartment security without drilling, wiring, or permanent installation. The Apartment Plus Kit combines flexible, battery-powered monitoring with high-resolution video and continuous recording—perfect for renters who want maximum protection with zero damage.
Wyze Battery Video Doorbell gives you a clear head-to-toe view of visitors with wire-free setup ideal for apartment doors.
Wyze Cam Pan v3 adds smooth 360° indoor tracking so you can follow activity across your living space without mounting hardware.
Wyze Cam v4 enhances your coverage with crisp 2.5K QHD video, Color Night Vision, and a built-in spotlight for sharp detail day or night.
Together, these products create a powerful, renter-friendly security system designed for apartment living.
  • A white Wyze Cam Pan v3 is shown in a black background.
    Wyze Pan Cam v3
    Wyze Cam Pan v3 delivers smooth 360° pan and 180° tilt with weather-resistant design, smart motion tracking, and clear HD video—giving you whole-room or outdoor coverage with easy, flexible placement.
  • Wyze Battery Video Doorbell - Black / No Chime - Head-to-Toe Viewing 1536 x 1536 HD+ Resolution Wire-Free or Wired Up to.
    Wyze Battery Video Doorbell gives you a wide head-to-toe view of visitors with sharp video, two-way audio, and smart motion alerts—all in a wire-free, renter-friendly design that installs anywhere.
  • A white camera with a blue light on it.
    Wyze Cam v4
    Wyze Cam v4 delivers sharp 2.5K QHD video, Color Night Vision, Wi-Fi 6 reliability, and a built-in spotlight—giving you clear, dependable indoor or outdoor monitoring day and night.
Instant visibility at your door with Battery Video Doorbell.
See every visitor and every delivery the moment they arrive. No wiring, no drilling. Battery-powered security for simple installation without submitting a maintenance request.
Wide head-to-toe view angle.
See more of what matters. With a 150° horizontal and 150° vertical field of view, Wyze Doorbell captures everything.
Keep an eye on packages, food delivery drop-offs, or your neighbor across the hall, all without blind spots. Even if someone stands close to the camera, you’ll still see the full picture — from head to toe.
A black device with a blue light on it.
No existing chime needed.
Apartment didn't come with a doorbell? No wiring needed when you pair with a Wyze Universal Wi-Fi Chime (sold separately) to hear alerts anywhere in your apartment, even through your Wyze Cams.
Shop Chime
Pan v3 sees the whole room with 360° pan and 180° tilt.
Cover the whole space with one device. Pan/ tilt to see the living room, kitchen, and entryway. Get alerts for movement or noise.
Keep an eye on motion.
Pan v3 detects motion and automatically follows it. Track pets moving around the apartment or check in on maintenance while you’re away.
Peace of mind while you're away with Cam v4
Secure a second room with 2.5K QHD resolution. Double check that you've turned off appliances or pets aren't getting into trouble. No wiring or mounting damage.
Record every second
24/7 Recording with MicroSD Card.
Record 24/7 locally with a microSD card (sold separately). Package missing? Noise complaints? Scrub through the timeline to see exactly what happened. Add AI alerts and cloud backup with Cam Plus.
