1 of 7
Wyze Plug
Wyze Plug
Smart In‑Wall Outlet
Best Selling
Everyone's Top Pick
Wyze Plug (Quantity)
$29.98
Use a 5-digit ZIP code.
Control Anywhere
with Wi-Fi
Dusk to Dawn Scheduling
Start living in the future. Make your normal ol' devices smart!
  • A black image of a phone being held.
    Controls Other Wyze Devices
  • Works with an app
    Works with an app
  • A black background with a white microphone icon.
    Works with Alexa and Google Assistant
  • A black background with a white calendar icon.
    Create schedules & use vacation mode
Weight and Materials
  • Color: White
  • Weight: 5.3 oz.
  • Dimensions (L x W x H):
    2.7" x 2.0" x 1.5"
Weather Resistance
  • Indoor use only
Operating Temperature
  • -4°F - 104°F / -20°C - 40°C
Input
  • 100-120 VAC, 60Hz 15A
Output
  • 15A Max
Compatibility
  • Android 5.0+, iOS 9.0+
Certifications
ETL
Warranty
1 Year
Connectivity
2.4GHz WiFi
Integrations
Alexa, Google Assistant, IFTTT
  • Wyze Plug x 2
  • Quick Start Guide x 1
Control from anywhere.
Wyze Plug gives you a simple way to turn on/off any outlet remotely. Easily control, lamps, fans, and other devices from the palm of your hand. No hub required.
A blue coffee maker with a white cup and a black plug.
A wall outlet with a desk fan plugged into it.
Keep the lights off when you're at work
Save energy with scheduling.
It's time to the hassle out energy savings.
Create schedules for your devices to turn on/off automatically at certain times of day or when you leave the house.
A phone screen with a coffee maker app on it.
Control with a powerful free Wyze app
Quick controls in the Wyze app.
Check to see if you left your Wyze Plug on and tap to turn it off remotely, right from the Wyze app.
Easily view daily and weekly run times and group multiple plugs together, controlling them all with one tap.
Air purifier with Alexa integration.
Use voice commands
Works with Alexa and Google.
Got your hands full? Command your devices using just your voice with Amazon Alexa and Google Assistant.
A house with a blue door and a white roof.
Make it look like you're home
Vacation Mode.
When enabled, Wyze Plug can turn your stuff on and off at random making it look like you're home, so people think twice about coming over uninvited.
An ecosystem that works together.
Your individual Wyze devices are awesome. As a team, the possibilities are endless. A light switch that unlocks the door. A lock that flips on the lights and cranks the AC. All of our smart devices can talk, what they say is up to you.
Image wall room with Wyze Cam v3, Wyze Thermostat, Wyze Switch, Wyze Video Doorbell, Wyze Floodlight and Wyze Lock
A white camera on a wall.
Support Articles
Download the Quick Start Guide for Wyze Plug in this article.
Below is the Quick Start Guide for Wyze Plug, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Plug including:
  • What's in the box for Wyze Plug.
  • How to set up your Wyze Plug.
  • How to read the status lights for Wyze Plug.
Wyze Plug is a smart plug you can control using Wi-Fi. Any device plugged into your Wyze Plug becomes a smart device that you can turn on and off with your smartphone.
Heads up: Check the back of your Wyze Plug for a key icon. If it has one, setting up your plug will be faster thanks to BluetoothⓇ.
To set up your Wyze Plug (2021 Version):
  3. Tap Power & Lighting > Wyze Plug.
  4. Make sure BluetoothⓇ is enabled on your phone.
  5. Insert your Wyze Plug into an outlet. The status light on the plug will flash blue, indicating it’s in pairing mode.
  6. In the Wyze app, tap Next. The app will set up your plug automatically. Make sure your phone is close to the plug.
  7. Once the plug is found and set up, select your network and enter your network password. Tap Next.
  8. If you bought your plug in 2021 or later, BluetoothⓇ pairing will be completed automatically.*
  9. Enter a name for your Wyze Plug, then tap Finish.
  10. On the Things to Try page, select Create or edit a device group to organize your Wyze devices into new or existing groups, or select Share this device to give family and friends access to your new Wyze device. Tap Skip to do this later.
  11. You’re all set. Enjoy your new Wyze device!
*If you bought your plug before 2021, tap I bought my plug before 2021. on the Bluetooth setup page then follow the steps below.
  1. Insert your Wyze Plug into an outlet. The status light on the plug will flash blue, indicating it’s in pairing mode.
  2. Then select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
  3. Select your Wyze Plug’s Wi-Fi and tap Connect.
  4. Back in the Wyze app, the plug will finish connecting automatically.
  5. Once complete, the status light will stop flashing and the app will prompt you to name the device.
  6. Enter a name for your Wyze Plug, then tap Finish.
  7. Set up some automations on the Things to Try* page, or tap Skip.
  8. You’re all set. Enjoy your new Wyze device!
Additional Notes:
  • Android, Samsung users: When connecting to your Wyze Plug’s network, be sure to stay connected to the Wi-Fi network when prompted that the network doesn’t have an internet connection instead of switching to mobile data. If you switch to mobile data, the setup process will stop.
  • Android, non-Samsung users: When connecting to your Wyze Plug’s network, be sure to accept the pop-up stating the network has no internet. Dismissing or denying this message will stop the setup process.
  • iOS 13+ users: Please check to make sure the Location Services permission is allowed in your settings. Here’s how to do this: Open the Settings app on your phone. Go to Privacy Settings. Go to Location Services. Make sure that the Wyze app is granted permission to use this while it’s running.
  • Note: If you have your Wyze Plug in a wall outlet that’s controlled by an on/off switch, ensure that the switch is turned on.
