Brighter, Bolder, & Better than ever
An all-new Starlight Sensor illuminates the outdoors in full color while weather resistance lets you capture life outside. Performance upgrades across the board make this Wyze’s most powerful smart cam ever.
Pierce through darkness with the all-new Starlight Sensor. This low-light amplifier shows dark areas in vivid, spectacular detail unseen even to the human eye.
It’s time to take Wyze Cam outside. All-new IP65 weather & dust resistance truly lets you see everything around your home, inside and out.
Wyze Cam v3 is wired allowing for continuous recording*.
* Requires microSD card (sold separately)
We didn’t just upgrade the look - we upgraded the whole fricken thing.
(Hear the loud Siren)
Save 12-second motion and sound Event videos to the cloud, for free. Videos are saved for 14 days at a time.
Capture and view up to 3 days of continuous video with a 32 GB microSD card (sold separately).
Take stunning time-lapse videos over long periods of time. Requires a 32 GB microSD (sold separately).
Receive an alert the moment Wyze Cam hears a Smoke or CO alarm go off. Wyze Cam records a video during this time.
From the big picture
To the small delights
And everything in between
Starlight CMOS Sensor helps you to see in ultra low-light conditions.
Wyze Cam v3 is capable of seeing in color at night with very limited lighting. You can even use it to watch the stars or take a time lapse of the stars.
IP65-rated weatherproof with extreme temperature tolerance from -4°F to 113ºF, the camera can be mounted anywhere inside or outside your home and stand up to any weather conditions.
An improved sensor and lens lets the v3 capture extraordinary images and videos in any light. It’s the best in its class.
Free 14-day cloud storage right out of the box.
Included storage gives you peace of mind right from the start. Add even more storage with a microSD card or a subscription to Cam Plus.
Put your Wyze Cam v3 anywhere you want.
Your camera can be mounted 3 ways - with the easy magnetic mount, secure screw mount, or the¼” mount onto your existing mount.
Say goodbye to push-to-talk.
Wyze Cam now comes with simultaneous 2-way communication. Talking to your family, pets and visitors is just like making a phone call.
The Near-IR lights for indoor use are invisible to the human eye so you won’t be annoyed by red dots. The far-IR light for outdoor use, to illuminate farther and see clearer.
Use the improved speaker as a siren to warn away intruders (and pesky squirrels) with a loud sound. Control the siren from the Wyze app.
White, with black accents
Body: Polycarbonate
Lens: Glass + Plastic
52 mm (L) x 51 mm (W) x 58.5 mm (D)
<98.8g
Android 5.0+
iOS 9.0+
IR Lights: 4x940 nm, 4x850 nm
Day/Night Vision
Mic: ECM
Speaker: 80db, waterproof
Simultaneous 2-way Talk
Siren
Power Adapter: Indoor 5v/1A
Outdoor Power Adapter (sold separately)
Cable: 6 Feet Flat USB Cable
CMOS Starlight Sensor
Front. Red + Blue.
2.4GHz WiFi
Local Storage (microSD card required)
Cloud
-5°F - 113°F (-20°C - 45°C)
IP65 Weather resistant
Indoor/Outdoor
FCC, IC, UL and IP65 Certified
English
1-Year
Wyze Cam v3 is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night.
Yes, absolutely. The v3 cam is rated for indoor and outdoor use.
While viewing the Live Stream, simply turn Night Vision off. A small amount of light is needed to create a clear image, but a street light outside or even a nightlight is enough. If your environment is pitch black, consider picking up our spotlight kit to help illuminate the scene.
The Starlight CMOS sensor is a sensor that is very sensitive to light. It allows the v3 to use extremely low light to create an astonishingly clear image.
We’ve improved the volume of the speaker so that it can be used as a siren, which is loud so you can use it to ward off intruders. Control the Siren feature from the Wyze app.
Yes, Wyze Cam v3 is powered by a USB cable but connects to the Internet via 2.4GHz WiFi.
No, the v3 does not support 5GHz WiFi. It supports 2.4GHz networks.
1920x1080p Full HD
The v3 does not support the Wyze Sense Bridge, but a standalone Wyze Sense Hub will be launched in the near future. You may keep on using Wyze Cam v2 or Wyze Cam PAN to support the current Wyze Sense Bridge.
No, Wyze Cam v3 is powered via a USB cable.
Day: 20 frames per second (fps)
Night: 15 fps
In comparison, the frame rate for the v2: Day/15 fps, Night/10 fps.
First, sign in or create a Wyze account — this is required. Then, purchase a Wyze device that includes 1-3 months of Cam Plus. No further action is needed! Your new Cam Plus license will be applied to your Wyze account automatically, and it will be activated once the device ships. Your Cam Plus subscription will not auto-renew unless you have added a payment method to your services.wyze.com account. Learn more.
© 2021 Wyze Labs, Inc
Amazon, Alexa, Echo Spot and all related logos are trademarks of Amazon.com, Inc. or its affiliates.
Google, Inc., Google, Google Home, Google Home Mini, G logo, The Google Assistant built-in, and related marks and logos are trademarks of Google, Inc. All rights reserved.
