1 of 3
Wyze Chime Controller
Works only with Wyze Video Doorbell v2 and Duo Cam Doorbell.
$17.99
Free Shipping & 30-day hassle-free returns.
Standalone chime controller unit. Only compatible with Wyze Video Doorbell v2 and Duo Cam Doorbell.
Compatible with Doorbell v2 and Duo Cam Doorbell
We all expect our chimes to ring when our doorbell cameras are pressed. With our chime controller unit, you can make new video doorbell technology work with your existing mechanical chime setup.
Close-up of hands installing controller for chime support
Works with your in-house chime
Ding dong. Hear alerts exactly where you want in your home with your Wyze cams.
*Note: Wyze Chime Controller works with most mechanical and digital chimes. Not compatible with Wyze Chime plug-in unit.
1 of 4
  • ✅ Compatible WOOHOO!
    Product: Wyze Doorbell v2
    FOV: 135 x 103°
    Resolution: 2K
    Chime: Wyze Chime Controller (for existing mechnical chimes)
    Installation: Screw mounting
    Local Storage: Supports up to 256 GB microSD card
    Mounting Location: Requires existing wiring
    Power: Wired (AC 16-24 V) only
    Product: Wyze Duo Cam Doorbell
    FOV: Top: 132x100°/Bottom: 121x60°
    Resolution: Top: 2K/Bottom: 1080p
    Chime: Wyze Chime Controller and Wyze Wi-Fi Chime
    Installation: 3M adhesive or screw mounting
    Mounting Location: Anywhere
    Power: Wyze Removable Battery Pack or Wired (AC 16-24 V)
  • ❌ Not compatible
    Product: Wyze Video Doorbell Pro
    Works with original Wyze Chime.
  • ❌ Not compatible
    Product: Wyze Doorbell (v1)
1 of 4
