1 of 10
Wyze Battery Cam Pro
Protect anywhere. See everything in 2.5K HDR.
No power outlet or electrician needed. Turn this wireless cam into a solar security cam by adding a Wyze Solar Panel.
Color
Pack
$89.98
Low stock: 33 left
$2.99 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
  • 2.5K HDR Video Resolution
  • Wire-Free, No Hub required
  • Integrated Spotlight & Siren
  • Radar + PIR Motion Detection
  • Removable, Rechargeable Battery Packs
  • IP65 Weatherproof
  • 2.4 & 5Ghz WiFi Support
Feature Highlight: Local recording (with a MicroSD card) is available for Battery Cam Pro
Weatherproof wire-freedom for all.
No wires. No hubs. It's the ultimate battery operated go-anywhere, see-everything home security camera. Get pro-grade protection precisely where you need it most.
1 of 5
Shop Wyze Battery Cam Pro Accessories
  • Wyze Removable Battery Pack
    Regular price $22.99
    Regular price Deal $22.99
    Works with Wyze Battery Cam Pro and Wyze Duo Cam Doorbell. Learn More
  • Wyze Battery Charging Dock
    Regular price $17.99
    Regular price Deal $17.99
    Charge up to two batteries at once. Learn More
  • Wyze Battery Cam Solar Panel
    Regular price From $5.99
    Regular price Deal From $5.99
    Record for longer. Designed for Wyze Cam Outdoor and Wyze Battery Cam Pro. Learn More
    Choose your option
    View Options
  • Wyze MicroSD Card
    Regular price From $8.99
    Regular price Deal From $8.99
    Choose your option
    View Options
  • Wyze Universal Mount (Long)
    Regular price $9.99
    Regular price Deal $9.99
    A durable mount with a longer stem. Required when mounting Wyze Battery Cam Pro to a ceiling. Learn More
Capture more details with 2K HDR & Color Night Vision.
Day or night, every detail matters. Wyze Battery Cam Pro utilizes high dynamic range for balanced images with richer colors.
Integrated light. Intruder flight.
Light up potential intruders with 150 lumens of LED, motion-activated light. You can also manually control the spotlight in the Wyze app for extra security while you’re walking the dog at night.
Radar + PIR = A motion detection superstar.
Double the motion sensors means double the "Gotcha!" Radar and PIR combine for earlier and more precise detections. Set custom detection zones in the Wyze app for location specific notifications.
Get even smarter detections with Cam Plus.
The power to protect.
Wyze Battery Cam Pro has flexible power & mounting options.
Removable battery packs.
Taking down your camera to charge it is as tedious and wearisome as cleaning an airport urinal. Easily hot-swap battery packs and eliminate security downtime.
Add to Cart
Ready power with Wyze Battery Charging Dock.
Charge up to two battery packs at once with Wyze Battery Charging Dock. Sold separately.
Add to Cart
Turn your cam into a Solar Powered Security Camera in seconds.
Nothing says, "I'd like to keep living on planet Earth" like a solar panel. Convert sun rays into power so you can leave your camera up longer with less frequent charging.
Add to Cart
Ceiling setup with Wyze Universal Mount.
Need to keep an eye high in the sky? Wyze Universal Mount has a longer stem for a flexible ceiling mount option. Required when mounting Wyze Battery Cam Pro to a ceiling or under an eave.
Add to Cart
Battery Cam Pro can locally record to a microSD card.
Never miss a moment and record motion events locally to a microSD card, no subscription required. Enabling this feature impacts battery life.
More Pro features you'll love.
Drip. Splash. Plop. No matter the weather, this camera cannot be stopped.
No more QR code scanning. Setup is quick and easy with BluetoothⓇ.
Talk (or yell) to anyone easily with a built-in microphone and speaker.
Up and monitoring in minutes. Watch how 👇
