1 of 5
Wyze Removable Battery Pack
Works with Wyze Battery Cam Pro and Wyze Duo Cam Doorbell.
⚠️ Compatible with Wyze Battery Cam Pro and Wyze Duo Cam Doorbell. Charging cable not included.
$22.99
Pack a punch with a replacement 6200mAh rechargeable battery designed for the Battery Cam Pro and Duo Cam Doorbell.
Long Battery Life
6200mAh of rechargeable battery power lasts up to 6 months on just one charge. You can place your camera outdoors and not worry about having a power outlet nearby.
Convenient Charging
Get charged up with just a cable. Our battery pack is equipped with a built-in USB-C charging port, making it a breeze to juice up with a standard USB-C charger.
1 of 4
Take your Wyze Battery Cam Pro system to the next level
  • Wyze Battery Charging Dock
    Regular price $17.99
    Regular price Deal $17.99
    Charge up to two batteries at once. Learn More
  • Wyze Battery Cam Solar Panel
    Regular price From $5.99
    Regular price Deal From $5.99
    Record for longer. Designed for Wyze Cam Outdoor and Wyze Battery Cam Pro. Learn More
    Choose your option
    View Options
  • Wyze Universal Mount (Long)
    Regular price $9.99
    Regular price Deal $9.99
    A durable mount with a longer stem. Required when mounting Wyze Battery Cam Pro to a ceiling. Learn More
  • Wyze MicroSD Card
    Regular price From $8.99
    Regular price Deal From $8.99
    Choose your option
    View Options
Designed for Wyze Battery Cam Pro and Wyze Duo Cam Doorbell
