Skip to content
1 of 6
Wyze Cam Floodlight v2 + FREE Color Filters
Transform your space with 6 pairs of color filters for every mood and occasion
SALE
$99.98 $114.96SAVE 13%
⚠️ Color Filters use adhesive. Repeated removal and reapplication may weaken adhesion over time.
  • 6 Vibrant Color Options
    Choose your colors to set the scene.
  • Transform Your Floodlight
    Your light, your vibe. Tone it down or jazz it up.
  • Compatible with Floodlight v1 & v2
    Use your existing Wyze Cam Floodlight v2/v1 (not compatible with Pro).
Wyze Cam Floodlight v2 Color Filter Tech Specs
Color
  • 3500K Warm White
  • Red
  • Blue
  • Green
  • Cyan
  • Purple
Material
  • High-transmittance plastic + adhesives
Dimensions
  • Width x Depth x Height (2.76 in x 0.79 in x 3.15 in / 7cm x 2cm x 8cm)
Weight
  • 0.16 lbs / 0.073kg
Compatible with
  • Wyze Cam Floodlight v1/v2
  • Color: White or Black
  • Finish: Matte
  • Mount: Wall/Ceiling
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • 2 dimmable LED light panels
  • 2800 total lumens of brightness
  • 5000K color temperature
  • Dimmable: Yes
  • 2K (2304 x 1296)
  • Night Vision
  • Color Night Vision
  • Hardwired 110 - 120V AC
  • -4°F - 140°F (-20°C - 60°C)
  • IP65 Water Resistance
  • Safe for outdoor use
Learn more
Connectivity & Compatibility
  • IEEE802.11 b/g/n. Wi-Fi 2.4 GHz b/g/n
Warranty
  • Floodlight v2: 18 months
  • Floodlight Color Filters: 12 months
  • x1 - Wyze Cam Floodlight v2 (assembled)
  • x1 - Quick Start Guide
  • x1 - Mounting Accessory Kit
  • x2 -Bracket Screws (#6, #8, and #10)
  • x1 - Ground Screw
  • x1 - Floodlight Screw
  • x1 - Rubber Stopper
  • x1 - Mounting Bracket
  • x2 - Wire Nuts
  • x1 - Hook
12 x Color Filters (6 pairs total, 2 of each color)
  • 3500K Warm White
  • Red
  • Blue
  • Green
  • Cyan
  • Purple
2 x Cleaning Wipe Packets
  • Each packet includes 1 wet wipe + 1 dry wipe
(Camera not included)
Use the perfect color for your home
Choose from 6 color options to add a fun, welcoming glow to holidays, celebrations, and everyday moments.
Quick and easy installation.
Just peel the protective film from the plastic filter, stick it to the floodlight, and you’re good!
Softer warm white lighting
Transform your floodlight with a softer warm glow.
Elevate your lighting experience even if you have our older Floodlight v1.
Weather resistant
It can handle anything Mother Nature can throw at it.
