Wyze Lock Bolt v2
Wyze Lock Bolt v2 gives you fast, secure keyless entry with a responsive fingerprint reader, backlit keypad, Bluetooth access, and detailed activity logs—offering convenient, reliable home security without fumbling for keys.
Wyze Battery Video Doorbell
Wyze Battery Video Doorbell provides a clear, head-to-toe view of visitors with crisp video, two-way audio, smart motion alerts, and long-lasting wire-free installation—ideal for doors without existing wiring.
Wyze Bulb Cam
Wyze Bulb Cam seamlessly combines a smart bulb with a hidden 2K security camera, offering discreet overhead monitoring, color night vision, and flexible lighting control—all powered from a standard light socket.
Wyze Cam v4
Wyze Cam v4 delivers sharp 2.5K QHD video, Color Night Vision, Wi-Fi 6 reliability, and a built-in spotlight—providing clear, dependable indoor or outdoor monitoring any time of day.
Touch once. You’re in.
Wyze Lock Bolt v2 uses a biometric fingerprint scanner to unlock your door in as little as 0.5 seconds, storing your fingerprint data locally on the lock—not in the cloud—so you can ditch keys without sacrificing security when you’re carrying groceries, kids, or luggage.
Front door control, even when you’re not home.
With built-in Wi-Fi, you can lock or unlock the door, check status, and view activity from the Wyze app—no matter where you are.
A battery-powered doorbell built to see the full picture.
Experience effortless front porch protection, no matter where you live. Easily install it wired or wire-free and view it all from anywhere in crystal-clear HD+ resolution.
Easy to install for homes and apartments.
Mount anywhere with the included hardware and corner plate for the perfect view. Ideal for renters or homeowners who want simple, secure installation without hassle.
Wide 160° View Sees More Space
Installation as easy as...
Brilliant setups
Wyze Cam v4
2.5K Camera with Night Vision & Spotlight
ip65 weather resistance
Place it anywhere.
Enhanced two-way talk
Clearer conversation.
Integrated Spotlight + Siren
More safety at night.
Record every second
Don’t miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
