Supplemental Terms for HOME MONITORING SERVICE
Updated: December 13, 2024
The following Supplemental Terms for Home Monitoring Service (“Home Monitoring Terms”) apply to your use of the Home Monitoring service (the “Home Monitoring Services”). These Home Monitoring Terms are in addition to, and not in lieu of, your rights and obligations under the Wyze Terms of Service (the “Standard Terms”), and the Standard Terms are incorporated by reference herein. Capitalized terms used but not defined herein have the meanings given to them in the Standard Terms. If there is a conflict between these Home Monitoring Terms and the Standard Terms, these Home Monitoring Terms will control for that conflict.
By accessing, subscribing to or using the Home Monitoring Services, you accept and agree to be bound by these Home Monitoring Terms and the Terms of Use of Noonlight, Inc. (the “Monitoring Service Provider”) located at https://www.noonlight.com/terms, except for Sections 2 (Accounts and Registration) and 8 (Payment) therein (as modified, the “Monitoring Service Terms”). If you do not agree to these Home Monitoring Terms and the Monitoring Service Terms, do not use the Home Monitoring Services or related Services.
PRIVACY
For information about how we collect, use, share and otherwise process information, please see our Privacy Statement. As a part of the Home Monitoring Services, you consent to Wyze sharing information and data submitted through the Home Monitoring Service with the Monitoring Service Provider in order to provide the Home Monitoring Service. Such information and data (which includes my home’s location, my telephone number, and certain sensor data relating to the emergency) and any other information or data you share with, or that is collected by, the Monitoring Service Provider in connection with the Home Monitoring Services will be used, shared and otherwise processed pursuant to the Monitoring Service Providers privacy policy located at https://www.noonlight.com/privacy, which Wyze has no control over or responsibility for.
The Home Monitoring Service
While you have an active Home Monitoring Service subscription, depending on your configurations, your Home Monitoring system may transmit an alarm notice to the Monitoring Service Provider automatically when an intrusion is detected by the Home Monitoring Service, or you use the emergency button in the Wyze App. Subject to these Home Monitoring Terms, we will provide the Monitoring Service Provider your phone number and then a Monitoring Service Provider agent will contact you via telephone or SMS. Unless you enter the PIN number you selected when setting up the Home Monitoring Service to deactivate the alarm notice, the Monitoring Service Provider will contact your local public safety answering point and request emergency responders be dispatched to your Monitored Property (as defined below).
The Monitoring Service Provider is an independent contractor of Wyze; there is no partnership, joint venture, employment, franchise, or agency relationship between the Monitoring Service Provider and Wyze.
Monitored Devices
Only those Products that are expressly certified and approved by Wyze to be compatible with the Home Monitoring Service (“Home Monitoring Products”) may be used and enrolled in the Home Monitoring Services. It is your responsibility to locate, install, operate and maintain your Home Monitoring Products in accordance with the instructions provided with the Home Monitoring Products and on the Site (including the Standard Terms and any Supplemental Terms relating to such Products) and to confirm the Home Monitoring Products are connected to an appropriate power source (including battery power, as applicable) at all times.
Monitored Property
Home Monitoring may only be used in connection with Home Monitoring Products installed in single-family residences within the United States which you own or legally occupy (each, a “Monitored Property”). You must provide the correct address of the Monitored Property where each Home Monitoring Product connected to the Home Monitoring Service is located. If the Monitored Property address you provide is not correct or current, the Monitoring Service Provider may be unable to request emergency responders be dispatched to the location where your Home Monitoring Product is actually located and/or emergency responders may be dispatched to an incorrect location.
Wyze or the Monitoring Service Provider may require that you provide verification of the Monitored Property address to reduce the risk of fraud and help ensure that emergency responders, if dispatched by the Monitoring Service Provider, are dispatched to the correct address. If you are required to provide such verification, the Home Monitoring Service will not be available for the Monitored Property and the Monitoring Service Provider will not respond to alarm notices until the verification process is complete. If you have an actual emergency before your Monitored Property has been verified, or at any time you are unable to promptly confirm that the Home Monitoring Service has facilitated contact with the proper authorities, you should immediately contact the police, fire department, 911 or appropriate emergency response service.
WITHOUT LIMITING OTHER RELEASES IN THESE HOME MONITORING TERMS OR THE STANDARD TERMS, YOU HEREBY RELEASE WYZE FROM ANY DAMAGES, LOSSES OR EXPENSES ARISING FROM, RELATED TO, OR CAUSED BY, THE UNAVAILABILITY OF HOME MONITORING SERVICES PRIOR TO, OR WHILE, YOUR MONITORED PROPERTY IS BEING VERIFIED.
Text Message and Telephone Call Authorization
When you register for a Home Monitoring Service subscription, you will be asked to provide a phone number for a device that can receive phone calls and text messages. You are required to immediately inform us if the telephone number that you have previously provided to us changes.
The Monitoring Service Provider may contact the number you provided in connection with your use of the Home Monitoring Services. You consent to receiving phone calls and text messages from the Monitoring Service Provider to the phone number that you provide by any means, including through an automated telephone dialing or texting system. Standard text messaging charges and data rates applied by your cell phone carrier will apply to text messages or data sent and/or received in connection with the Home Monitoring Service. The ability to receive texts is an integral part of the Home Monitoring Service; therefore, to no longer receive text messages, you must cancel your subscription for the Home Monitoring Service.
Service Interruptions
While we aim for the Home Monitoring Services to be highly reliable and available, it is not intended to be reliable or available 100% of the time. The Home Monitoring Services are subject to sporadic interruptions and failures for a variety of reasons, including those beyond Wyze’s control, such as service provider (including Home Monitoring Provider) and mobile operator uptime. Additionally, in the event of any service interruptions to your Monitored Property’s Wi-Fi network or internet connection, or to your mobile, telephone and other network connections with respect to the Wyze App, the Home Monitoring Service may be unreliable or unavailable for the duration of such interruption. Wyze does not monitor for interruption in the connection of your Home Monitoring Products or other services upon which the Home Monitoring Service may depend to function properly and will not alert you should your Home Monitoring Products go offline. You are solely responsible for ensuring proper connections for transmission of data with respect to the Home Monitoring Products.
WITHOUT LIMITING OTHER RELEASES IN THESE HOME MONITORING TERMS OR THE STANDARD TERMS, YOU HEREBY RELEASE WYZE FROM ANY DAMAGES, LOSSES OR EXPENSES ARISING FROM, RELATED TO, OR CAUSED BY, ANY INTERRUPTIONS IN THE HOME MONITORING SERVICE.
Permit and Registration Requirements
Your use of the Home Monitoring Service may be subject to permit, registration, license or other regulations imposed by government or municipal authorities with jurisdiction over your Monitored Property or your use of the Home Monitoring Service. If you, as a Home Monitoring Services subscriber, are required to comply with such regulations, then you are solely responsible for compliance, including to obtain, maintain and renew any required permits, registrations or licenses. This responsibility includes paying any applicable fees and renewal fees.
If you do not comply with these regulations, emergency responders may not respond to requests from the Monitoring Service for emergency dispatch, and/or your government or municipal authorities may impose fines, penalties or other fees. Therefore, neither the Home Monitoring Service nor the Monitoring Service Provider will respond to alarm notices you transmit or dispatch emergency response personnel until you have provided the Monitoring Service with evidence of all necessary permits, registrations, and licenses. You are responsible for any fees that may be assessed by the applicable government or municipal authorities against you or Wyze arising from your failure to comply with any such requirements. You will indemnify and hold harmless Wyze for any such fees and, to the fullest extent permitted by applicable law, you expressly authorize Wyze to, in its sole discretion, satisfy your indemnification obligation by billing or charging any payment method associated with your Wyze account the full amount of the fee.
WITHOUT LIMITING OTHER RELEASES IN THESE HOME MONITORING TERMS OR THE STANDARD TERMS, YOU HEREBY RELEASE WYZE FROM ANY DAMAGES, LOSSES OR EXPENSES RESULTING FROM OR AS A CONSEQUENCE OF YOUR FAILURE TO OBTAIN, MAINTAIN AND RENEW ANY REQUIRED PERMITS, REGISTRATIONS OR LICENSES FOR YOUR USE OF THE HOME MONITORING SERVICES.
False Alarms
Government or municipal authorities with jurisdiction over the Monitored Property may assess fines, penalties or other fees for false alarms, excessive alarms, or failing to comply with regulations or standards intended to reduce false alarms. You are responsible for any such fees that are assessed against you or Wyze. You will indemnify and hold harmless Wyze for any such fees and, to the fullest extent permitted by applicable law, you expressly authorize Wyze to, in its sole discretion, satisfy your indemnification obligation by billing or charging any payment method associated with your Wyze account the full amount of the fee.
WITHOUT LIMITING OTHER RELEASES IN THESE HOME MONITORING TERMS, YOU HEREBY RELEASE WYZE FROM ANY DAMAGES, LOSSES OR EXPENSES RESULTING FROM OR AS A CONSEQUENCE OF FALSE ALARMS.
Emergency Response
Wyze cannot guarantee that emergency responders will be dispatched to your Monitored Property in the event of an emergency. There may be a delay in or failure to dispatch emergency responders due to availability, local regulations not permitting dispatch of emergency responders to alarm signals which have not been verified by a person physically at the property, or other reasons beyond Wyze’s control. Our obligation to provide Home Monitoring is satisfied by allowing the Monitoring Service to trigger an alarm, and to receive alarm notices you transmit by your use of the alarm button in the Wyze App or the associated Home Monitoring Products. Anytime you are unable to promptly confirm that Home Monitoring has facilitated contact with the proper authorities, you should immediately contact the police, fire department, 911 or appropriate emergency response service.
CONSENT TO RECORDING
Certain federal and state laws prohibit interception and recording of telephone calls and other oral communications by electronic means, including the interception and recording of telephone calls and other oral communications by the Home Monitoring Services at the Monitored Property. You, for yourself and any other person contacting Wyze or the Monitoring Service Provider or whose communication is received from the Home Monitoring Services, whether by Wyze or the Monitoring Service Provider, (collectively, “Users”), consent to the interception, recording, disclosure and use of the contents of any telephone call, other oral communications or video in connection with the Home Monitoring Services. In addition, you will notify all Users with respect to any such interception, recording, disclosure or use. YOU WILL NOT INTERCEPT OR RECORD ANY ORAL COMMUNICATION OF ANY PERSON WITHOUT HAVING SUCH PERSON'S PERMISSION TO DO SO. Please refer to our Privacy Statement for important information regarding recording audio or video.
HOME MONITORING SERVICE SUBSCRIPTION
Subscription
Use of the Home Monitoring Services requires purchasing and maintaining a Home Monitoring Service subscription. See Section 7(I) of the Standard Terms for more information about how you will be charged for your subscription. Your subscription automatically renews unless you cancel it.
Cancellation
You may cancel your subscription at any time and for any reason by visiting https://my.wyze.com/account/services. If you have any concerns or questions, you can reach out to 206-339-9646. However, if you do so, Wyze will not refund any Fees for the Subscription Period for the Home Monitoring Services that have been validly charged, debited or otherwise billed to your account as of the date of such termination.
If you cancel during a trial period, you might lose access to content immediately.
Please remember that you must cancel twenty-four (24) hours in advance of the start of a new Subscription Period to avoid being charged for that Subscription Period. For example, if your subscription begins on January 1, you must cancel at least twenty-four (24) hours before February 1, which means you must cancel on January 30 to avoid being charged for the Subscription Period beginning February 1.
After you cancel your subscription to the Home Monitoring Services, you will continue to have access to the Home Monitoring Services until the end of your current Subscription Period. At that time, your subscription and access to Home Monitoring will end, and the Monitoring Service Provider will no longer receive alarm notices from you.
WYZE IS NOT AN INSURER
Wyze is not an insurer of you, your Monitored Property, other persons living in or present at your Monitored Property, or the contents of your Monitored Property.
YOU SHOULD PROTECT AGAINST ANY RISK OF LOSS WITH APPROPRIATE INSURANCE COVERAGE, AND YOU ARE RESPONSIBLE FOR OBTAINING ALL INSURANCE COVERAGE YOU BELIEVE IS NECESSARY. THE FEE IS BASED ON THE VALUE OF THE SERVICES WE PROVIDE AND OUR LIMITED LIABILITY UNDER THIS AGREEMENT AND NOT ON THE VALUE OF YOUR MONITORED PROPERTY, ITS CONTENTS OR THE LIKELIHOOD OR POTENTIAL EXTENT OR SEVERITY OF INJURY (INCLUDING DEATH) TO YOU OR OTHERS. THE LIMITATION OF LIABILITY, WAIVERS AND INDEMNITIES SET FORTH IN THIS AGREEMENT ARE A FAIR ALLOCATION OF RISKS AND LIABILITIES BETWEEN YOU, US AND ANY AFFECTED THIRD PARTIES.
DISCLAIMERS
YOU ACKNOWLEDGE THE HOME MONITORING SERVICES MAY CONTAIN BUGS, ERRORS, AND DEFECTS. ACCORDINGLY, THE HOME MONITORING SERVICES ARE PROVIDED "AS IS," WITH ALL FAULTS, DEFECTS AND ERRORS, AND WITHOUT WARRANTY OF ANY KIND. WYZE DISCLAIMS ALL WARRANTIES (EXPRESS OR IMPLIED AND ARISING BY LAW OR OTHERWISE) REGARDING THE HOME MONITORING SERVICES AND THEIR PERFORMANCE OR SUITABILITY FOR YOUR INTENDED USE, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTY OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT. WYZE HAS NO LIABILITY OF ANY KIND FOR THE USE OF OR INABILITY TO USE THE HOME MONITORING SERVICES OR FOR ANY LOSS OF DATA.
RELEASE
WITHOUT LIMITING OTHER RELEASES IN THESE HOME MONITORING TERMS OR THE STANDARD TERMS, TO THE FULLEST EXTENT PERMITTED BY APPLICABLE LAW, YOU (I) RELEASE WYZE FROM ALL LIABILITY FOR ANY LOSS, OCCURRENCE, EVENT OR CONDITION, WHETHER OR NOT COVERED BY YOUR INSURANCE, (II) RELEASE WYZE FROM ANY CLAIMS OF ANY PARTIES SUING THROUGH YOUR AUTHORITY OR IN YOUR NAME, SUCH AS YOUR INSURANCE CARRIERS, AND (III) WAIVE AND RELEASE ANY SUBROGATION AND OTHER RIGHTS YOU OR YOUR INSURANCE COMPANY MAY HAVE AGAINST WYZE FOR MONEY PAID TO YOU OR ON YOUR BEHALF. YOU WILL NOTIFY YOUR INSURANCE CARRIER(S) OF THESE RELEASES.
TO THE FULLEST EXTENT PERMITTED BY APPLICABLE LAW, WYZE AND THE OTHER WYZE PARTIES WILL NOT BE LIABLE TO YOU UNDER ANY THEORY OF LIABILITY—WHETHER BASED IN CONTRACT, TORT, NEGLIGENCE, STRICT LIABILITY, WARRANTY, OR OTHERWISE—FOR ANY INDIRECT, CONSEQUENTIAL, EXEMPLARY, INCIDENTAL OR SPECIAL DAMAGES OR LOST PROFITS, EVEN IF WYZE OR THE OTHER WYZE PARTIES HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
THE TOTAL LIABILITY OF WYZE AND THE OTHER WYZE PARTIES FOR ANY CLAIM ARISING OUT OF OR RELATING TO THESE HOME MONITORING TERMS OR OUR PRODUCTS OR SERVICES (INCLUDING, WITHOUT LIMITATION, THE HOME MONITORING SERVICES), REGARDLESS OF THE FORM OF THE ACTION, IS LIMITED TO THE GREATER OF $500 OR THE AMOUNT PAID BY YOU TO PURCHASE OUR PRODUCTS OR USE OUR SERVICES, AS APPLICABLE.
THE LIMITATIONS SET FORTH IN THIS SECTION WILL NOT LIMIT OR EXCLUDE LIABILITY FOR THE GROSS NEGLIGENCE, FRAUD OR INTENTIONAL MISCONDUCT OF THE WYZE PARTIES OR FOR ANY OTHER MATTERS IN WHICH LIABILITY CANNOT BE EXCLUDED OR LIMITED UNDER APPLICABLE LAW. ADDITIONALLY, SOME JURISDICTIONS DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATIONS OR EXCLUSIONS MAY NOT APPLY TO YOU.
CUSTOMER SUPPORT
If you have any questions or concerns regarding the Home Monitoring Services or these Home Monitoring Terms, please visit https://support.wyze.com. Customer Support is subject to availability of applicable Wyze personnel and is limited to responding to inquiries sent through standard email and other established Wyze communication channels.
Wyze does not provide any commitments or guarantees as to response times or as to whether problems or concerns can be resolved or addressed. Any customer service and support offered and provided by Wyze is not an emergency or 911 service or a dispatch center, an emergency service provider or dispatch service, or a lifesaving solution for people at risk in their home or otherwise. PLEASE DO NOT CONTACT CUSTOMER SERVICE OR SUPPORT OFFERED BY WYZE WITH ANY LIFE/SAFETY OR SECURITY EMERGENCY, MEDICAL EMERGENCY, OR ANY OTHER EMERGENCY. IF YOU HAVE ANY SUCH EMERGENCY, YOU SHOULD IMMEDIATELY CONTACT THE POLICE, FIRE DEPARTMENT, 911 OR APPROPRIATE EMERGENCY RESPONSE SERVICE
