Window Cam
4.1 out of 5 stars · 765 reviews
Quantity
13M+ Households Trust
In stock 30-day returns Secure checkout
Included Free
Cam Plus Trial
All AI features + cloud recording, free for 30 days.Then $2.99/mo · cancel anytime.
Free/30 days
Add StorageSmarter Storage
Why Wyze
Wyze.com Exclusive Benefits 18-month Extended Warranty
Why Wyze
Window Cam Features
Peel-and-stick mount
10ft cable
2K HD video
Motion alerts
Two-way talk
Color night vision
Alexa & Google
microSD backup
Tech specs
Camera
Model
WYZECWC
Color and finish
White; textured matte
Image sensor
1/2.9-inch CMOS, 1920 × 1080
Dimensions
2.05 × 2.05 × 2.05 in (52 × 52 × 52 mm)
Weight
2.75 oz (76 g)
Field of view
120° diagonal / 101° horizontal / 53.9° vertical
Digital zoom
8×
Power and ports
Power adapter input
100–240V, 50/60Hz
Power adapter output
5V/1A
Cable
10 ft (3 m)
Port
1 micro-USB port
Audio and storage
Audio
Built-in 100 dB speaker and microphone with noise/echo cancellation
Local storage
Up to 512 GB microSD (exFAT)
Connectivity
Wi-Fi
802.11 b/g/n, 2.4 GHz (Wi-Fi 4/5/6)
App requirements
Android 9+ / iOS 15+
Integrations
Alexa, Google Assistant, IFTTT
Environment and support
Placement
Indoor only
Operating temperature
−14°F to 113°F (−10°C to 45°C)
Storage temperature
−40°F to 158°F (−40°C to 70°C)
Language
English
Warranty
1 year
What's in the Box
  • Wyze Window Cam
  • 2× Mounting Stickers
  • Cable Clips
  • USB Cable (10 ft)
  • Indoor Power Adapter
  • Quick Start Guide
FAQ
Peace of Mind.
Don't take our word for it
13,000,000+
Households Trust
Here's what they have to say about
Window Cam
"I own the night!"
"Amazing quality at night. I can finally see what is going on in my backyard when we sleep!!"
Mark S.
"Recognizes my pets"
"The camera is clear and accurate. I was astonished that it recognizes my pets, our animals range from dogs, chickens, and rabbits."
Amanda K.
"Alerts for pets, people and vehicles!"
"The window cameras are incredible easy to setup and get going. The picture quality is amazing, alerts for pets, people and vehicles!"
Jen
"Not visible from the outside"
"I like the way the camera stays on the window and is not visible from the outside."
Rosie
"Safe from outside elements and people"
"Love the fact that it's easy to mount inside and safe from outside elements and people."
Verified Customer
"Excellent picture quality!"
"Have had Ring since it came out. Really like the size and ease of installation with the Wyze window cam. Excellent picture quality!"
Dub
"Sweet product."
"Sweet product. Setup is a breeze… Picture is very crisp, wide, and has great detail. Best of all, no hint of glare or reflection from glass whatsoever."
Paul K.
"Accurately identifies cars and people"
"The coverage is excellent, and the motion detection, which accurately identifies cars and people, is incredibly helpful."
Verified Customer
"Window Cam…wow!"
"This new camera not only lets you mount it without glare, the night vision is incredible! It looks like daylight even without any moonlight. We can finally see what critters are eating our vegetable garden!"
David D.
"Incredible Optics"
"I went to bed and was checking my footage and found out that the camera had managed to capture the Northern Lights, which were not visible to the naked eye! What a lovely surprise."
Merlin
"Almost looks daylight outside"
"I have been amazed at the quality of the nighttime video recordings. It almost looks daylight outside with about only the light of half a moon."
Verified Customer
Peel. Stick. Plug.
Easy Install On your window in
seconds
  • Easy setup
  • Anti-glare
  • Night vision
  • 24/7 recording
  • 10 ft cable
  • Motion zones
  • Watch live
  • Timelapse
  • Smart home
Easy window mount
No tools.
Just stick.
Mounts indoors on clean glass with a secure hook-and-loop sticker. No ladder, drill, or weatherproof cable run.
Anti-glare design
See outside,
without glare
Wyze Window Cam anti-glare window footage
A purpose-built mount blocks indoor reflections so the footage stays crisp through the glass.
Pro Color Night Vision
See the night
in full color
Upgraded Color Night Vision
Competitor Color Night VisionCompetitors
The f/1.0 aperture and BSI sensor pull usable color from a whisper of ambient light.
Motion detection
Instant alerts
on your phone
Wyze Window Cam instant motion alert on phone
With Cam Plus, AI detects people, pets, packages, and vehicles, while ignoring squirrels and tumbleweeds.
Local recording
Record 24/7
to microSD
Wyze Window Cam local microSD recording
Store days, weeks, or months locally on a microSD card up to 512 GB. microSD card sold separately.
Motion zones
Watch just
what matters
Wyze Window Cam motion detection zones
Draw the exact areas you want watched, driveway, walkway, porch. Ignore the rest.
Smart home
Control with
your voice
Wyze Window Cam works with Alexa and Google Assistant
Works with Alexa, Google Assistant, and Wyze Automations for hands-free control.
Timelapse
See a day in
seconds
With Timelapse, capture a sunrise, storm, or a whole day of progress and stitch it into a shareable clip.
Fast pair
Quick & easy
connection
Wyze Window Cam fast Bluetooth pairing with WiFi 6
Pair over Bluetooth in seconds, then stream smoothly over WiFi 6.
Roll the tape.
Window Cam
4.1 out of 5 · 765 reviews
Good questions
Asked, Answered.
Wyze Window Cam is built specifically to be used behind window glass. Unlike our other Wyze Cams, we removed the IR lights and the spotlight entirely to reduce glare and reflections that cause poor image quality at night. We made installation as simple as peeling, sticking, and pressing it onto a clean window. Last, we included an extra-long micro USB cable and cable clips for neat and tidy mounting.
To remove the adhesive from a window, start by applying heat from a hair dryer to soften the adhesive, then use a plastic scraper or a card to gently pry it away. For stubborn residue, a solvent like isopropyl alcohol can dissolve the sticky material. Finish by wiping the area with a clean cloth and washing with soap and water.
No, the mounting sticker is for single-use only, and cannot be moved and reused after mounting. However, Wyze Window Cam comes with two mounting stickers in case you want to mount it somewhere else.
Always thoroughly wipe clean and dry the area on your window before axing the sticker. Or replace with the spare window sticker that comes in the box.
We do not recommend placing the camera behind a screened window as it will negatively impact video quality.
The bigger sticker is to minimize glare caused by indoor lighting behind Wyze Window Cam. Please make sure you mount the sticker horizontally for best results. Do not trim the sticker.
FREE shipping on orders $0+
