1 of 6
Wyze Floor Lamp
Wyze Floor Lamp
Shine a focused light on what matters.
$64.99
Use a 5-digit ZIP code.
  • 15 Individual Condenser Lenses
  • Bluetooth Remote for 11 Levels of Brightness Adjustment
  • 23° Precise Directional Lighting
  • High Color Rendering (RA>90)
Wyze Floor Lamp Stand
  • Weight: 7.06 lbs
  • Dimensions: 11.82 in x 11.82 in x 73.76 in
  • Working voltage: 120 VAC 60Hz 1A
Wyze PARB Bulb
  • Shape: PAR30
  • Base Type: E26
  • Brightness: 800 lumens
  • Color temperature: 4000K Cool White
  • Rated power: 9.0 watts
  • Life expectancy: 25,000 hours
  • Bluetooth version: BLE 5.0
Operating temperature
  • -4°F - 104°F (-20°C - 40°C)
Storage temperature
  • -4°F - 131°F (-20°C - 55°C)
Dimensions
  • 3.73 in x 3.73 in x 4.65 in
Working voltage
  • 120 VAC 60Hz
Wyze PARB Remote
  • Bluetooth version :BLE 5.0
  • Battery: AAA/LR03 x1
Storage temperature
  • Wyze Floor Lamp Stand x1
  • Wyze PARB Bulb x1
  • Wyze PARB Remote x1
  • AAA/LR03 Battery x1
  • Quick Start Guide x1
Wyze Floor Lamp uses BLE 5.0 technology. Please make sure your Bluetooth is turned on on your phone when pairing the floor lamp with your Wyze app.
PAR is an acronym for parabolic aluminized reflector. BR stands for bulged reflector. When you put them together, you have a PARB bulb! This is a description for what kind of bulb is in the lamp.
Wyze Floor Lamp is a smart lamp that is embedded with special technology so that the bulb and remote work together with the Wyze app. Other E26 base bulbs, even other Wyze smart bulbs, cannot connect with the remote or Wyze Floor Lamp in the Wyze app. You won’t be able to turn off the light with the cord switch or control it with the remote button. Lastly, the included Wyze PARB Bulb has a minimalist aesthetic design that fits perfectly in the lamp assembly. Other bulbs just can’t compare!
You can control the lamp with the remote up to 50 feet away. This may vary depending on if there are any obstacles in the way.
Yes, the lamp and remote work without the app. You do not need to be connected to the Wyze app to use the basic functions of Wyze Floor Lamp and the remote. However, we encourage you to download and use the Wyze app for advanced features like Schedules, Smart Dimming, and more.
We do not evaluate or test Wyze Floor Lamp as a horticultural luminaire. It may emit light at wavelengths that are good for growing plants, but we suggest that you use it in the environments specified in our Quick Start Guide.
Wyze Floor Lamp’s light does not change colors. The color temperature is 4000K Cool White only.
Shape: PAR30. Base type: E26. Lux: 1400.* Lumens: 800. Color temperature: 4000K Cool White.
* Lux measures luminous flux per unit area; when the bulb is positioned at 4’7” from the surface or object, the center brightness can reach up to 1400lx.
The dimming level range for the bulb is 2%-100% with the Wyze app. The remote provides 11 levels of brightness.
The remote does not work with other devices, including Wyze Bulb and Wyze Bulb Color.
No, Wyze Floor Lamp does not currently support integrations.
The Super Focused 23° Light Beam provides you with a super-focused light for any task or activity. The focused light will shine only for your dedicated work, without disturbing others around you.
The gooseneck can stretch or bend in any direction. Its versatile stretchability lets you easily twist it into any position you need.
The 4100K Cool White color temperature provides excellent lighting for your Instagram videos and photoshoots. It does not, however, replace a professional lighting kit.
A light bulb with a condenser lens.
15 individual condenser lenses provide an even lighting experience
Traditional floor lamps often have light dispersion problems that make books harder to read, colors harder to identify, and strain the eyes. We've solved this problem using 15 groups of individual condenser lenses to confine light with a sharp 23° angle so you can have even lighting for whatever you're doing.
A close-up view of a bluetooth chipset and rotary encoder in a floor lamp.
Fine-tune your brightness with Bluetooth remote and 11 levels of lighting
The more you use the lamp, the more it learns your preferences using AI Deep Learning. In just a few uses, Wyze Floor Lamp learns your desired settings and turns on to the brightness level you want.
Super focused 23° light shines for your dedicated work
15 groups of individual condenser lenses make this the first floor lamp with truly directional lighting. Directional lighting makes it possible to focus light exclusively on your work without disturbing others around you.
A light shining at 23 degrees.
Unique 5’ 11” lamp stand with flexible neck lets you shine light in any direction
We designed a rare 5’ 11” lamp stand with a 2’ flexible neck so you can easily light up anywhere you want from sofas and recliners to workstations and ceilings.
A floor lamp with a light on in a living room.
Truer colors and finer details for drawing, crafting, and puzzles
Wyze Floor Lamp has an exceptionally high Color Rating Index (CRI) of 90+. When paired with the 23° light, a premium lighting experience is provided to bring out more vivid and truer colors.
A person is building a floor lamp with legos.
90+ CRI rating
The center brightness can reach up to 1400lx International Grade A brightness level.* *when the bulb is positioned at 47" from the surface or object
A person is coloring a picture on a piece of paper. A person is coloring a picture with a pencil and a coloring book.
Regular Lighting Brightness: 400lx - 800lx
Wyze Floor Lamp 1400lx
A smartphone app displaying a floor lamp brightness setting.
A smartphone app displaying a floor lamp's brightness schedule.
A smartphone app displaying a timer for a Wyze floor lamp.
A smartphone app displaying a floor lamp schedule.
Connects to the Wyze app for more smart lighting options (Bluetooth only)
Wyze Floor Lamp can be connected via the Wyze app for remote control, scheduling timers, smart dimming, sleep mode, and more. Wyze Floor Lamp can be updated through the app to add more lighting experiences and features after purchase.
Control via the Wyze App for on/off and 100 brightness levels
Through the Wyze App, you can learn the status of Wyze Floor Lamp for current brightness preference and next schedules.
With Delay Timer on the app, Wyze Floor Lamp will be turned on or off after a set period of time. You can set it as a bedtime light.
With Schedules on the app, Wyze Floor Lamp will automatically turn on, turn off or adjust the brightness levels.
A black floor lamp with a white base.
So low-profile it gets cleaned by the Wyze Robot Vacuum
0.5” Base - Weighs 5 lbs
A woman taking a selfie in a dimly lit room.
4000K daylight color temperature provides professional-grade lighting for portraits.
Take professional pictures or film incredible video with 90+ CRI and 4000K daylight color temperature paired with the concentrated beam of the lamp.
Support Articles
Once assembled, Wyze Floor Lamp works right out of the box. Plug the lamp in and toggle the cord switch to turn the light on and off.
To use it with the BluetoothⓇ remote button and the Wyze app, you must set it up using the steps in this article. Trust us - you want to do this to get the most out of your lamp!
Before you begin, download the Wyze app and sign in or create a Wyze account.
In the Box:
  • Wyze PARB Bulb x1
To set up your Wyze Floor Lamp:
  1. Unpack the Wyze Floor Lamp box, including the lamp parts and BluetoothⓇ remote.
  2. Assemble your Wyze Floor Lamp using the Quick Start Guide.
  3. Install the AAA battery into Wyze PARB Remote (the BluetoothⓇ remote).
  4. In the Wyze app, tap Home, then tap the plus sign + on the top right.
  5. On the Add menu, tap Device.
  6. Tap Power & Lighting > Wyze Floor Lamp.
  7. Plug the floor lamp into a power outlet.
  8. Toggle the cord switch to turn the light on. Tap Next in the Wyze app. Move your phone close to the lamp. The Wyze app will finish pairing.
  9. Name your Wyze Floor Lamp or choose from the list of suggestions. Tap Next.
  10. On the sharing screen, tap Maybe Later. In the next steps, you'll pair the BluetoothⓇ remote to your Wyze Floor Lamp. You can share the floor lamp later. Tap Next.
  11. Toggle the cord switch again. Tap Next.
  12. Pop out the side button on the BluetoothⓇ remote to enter pairing mode. Tap Next. The LED light will begin flashing.
  13. Press the big button on the center of the BluetoothⓇ remote. Tap Next. The lamp's lightbulb will pulse while pairing. It will steady when pairing is complete.
  14. Press the side button on the BluetoothⓇ remote to exit pairing mode.
  15. Test the remote by rotating the big button. If the brightness changes, pairing was successful. Tap Done.
  16. Enjoy your new Wyze device!
Download the Quick Start Guide for Wyze Floor Lamp in this article.
Attached is the Quick Start Guide for Wyze Floor Lamp, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Floor Lamp including:
  • What's in the box for Wyze Floor Lamp.
  • How to assemble your Wyze Floor Lamp.
  • How to use your Wyze Floor Lamp
  • How to use the remote for Wyze Floor Lamp.
  • How to troubleshoot your Wyze Floor Lamp.
Assembling your Wyze Floor Lamp should only take a few moments. Most parts are already assembled and just need to be twisted to tighten!
To assemble your Wyze Floor Lamp:
  1. Remove all lamp parts from the packaging.
  2. Pull the cord through the base to tighten the pole connections.
  3. Screw the upper pole into the gooseneck.
  4. Screw the upper pole into the lower pole.
  5. Screw the lower pole into the base.
  6. Screw the bulb assembly into the gooseneck.
  7. Insert plug into the power outlet.
Here's a Wyze Floor Lamp diagram of the how the base, poles, gooseneck, bulb assembly, and cord switch should be put tightened.
FREE shipping on orders $0+
