1 of 5
Wyze Car
Wyze Car
It's time to shift into fun.
Style
Use a 5-digit ZIP code.
Item is no longer available.
Traverse all types of terrain, from hardwoods to backwoods with all-wheel drive. A LED headlight for day or night driving. Get the best mileage with 2 battery modes (Sport and Eco Modes). Realistic, first-person perspective with up to 2 hours of operation on a single charge. Wyze Car's app lets you see what the car sees. WiFi Direct allows you to drive the Wyze Car anywhere, without worrying about losing connection.
  • LED headlight
    Light up your night missions
  • All-wheel drive
  • 2 hours of drive time
    Packed with a 10,000 mAh power bank
  • Multiple modes
    Eco-mode and Sports mode to match your need
Wyze Car Device Details
  • Color :Black
Materials
  • Car body: Polycarbonate
Weight
  • 2.2 lbs
Dimensions
  • 305 mm x 188 mm x 147 mm
LED Headlights
  • Color temperature: 6000 K
  • Brightness: 70 lumens
Max Speed
  • Eco Mode: 1.5 mph
  • Sport Mode: 2 mph
Phone Compatibility
  • Android 5.0+
  • iOS 9.0+
Battery Life
  • Standby: Up to 20 hours
  • Active: Up to 2 hours (driving)
Driving Controls
  • Forward, Reverse, Left and Right turning
Wyze Cam Features
  • Live Stream
  • 2-Way Audio
  • Record
  • Take Photo
Power Bank Device Details
  • Color: Black
Weight
  • 7.4 oz
Dimensions
  • 106 mm x 51 mm x 25 mm
Rated Capacity
  • 10,000 mAh
Input
  • 5V2A, 9V2A
Output
  • 5V3A
  • Wyze Car x1
  • Wyze Car Power Bank x 1
  • Rubber Band x2
  • Short Screw x8
  • Long Screw x4
  • Screwdriver x1
  • Anti-slip Tape x2
  • Guardrail x1
  • Quick Start Guide x1
  • Micro USB Cable x1
No, Wyze Car only works with Wyze Cam Black (for stealth!) and Wyze Cam v2.
Yes, discreetly hidden in your phone’s Wyze app. Use the remote to drive forwards, backwards, left, and right.
Yes, you can drive Wyze Car outside with or without Internet. Go out and explore (but keep it clean).
No, and the car should not be driven in rain, snow, deep puddles, or mud.
Sadly, no. You’d just get stuck and void the warranty!
Wyze Car does not take batteries, but it uses a rechargeable power bank with an output of 5V3A.
While it can be used to power other devices, ours is meant to be used with your Wyze Car.
About as much as your girlfriend can fit in that tiny pocket on her jeans.
Burn rubber with speeds up to 2 mph in Sport Mode (1.5 in Eco Mode).
Feel free to decorate your Wyze Car however you want with stickers. Might we suggest flames to make it go faster?
Compete? They’re nowhere even near the same class of product as us. This is a toy car.
It’s not out of the question. But probably not.
A person holding a cell phone with a Wyze Car app banner on the screen.
Control Wyze Car from the safety of your HQ
We’ve enlisted our top engineers to discreetly hide Wyze Car’s remote directly in a classified app on your phone. With the app, you'll be able to live stream your mission through your phone while completing your mission objectives from a safe distance away from the action. It goes without saying, but we absolutely cannot have another cover blown like the Jimmy from Wyze incident last year when the joystick fell from his pocket during cocktail hour.
  • Record
    Capture, and save video of your mission for debriefing.
  • Retrieve
    Critical information about your targets by getting up close and personal.
  • Recover
    Wyze Car by navigating it home remotely with the app.
WyzeCar Banner 1: A black and blue image of a car with a blue light on the front.
Get out of dodge when things get sticky
We can’t have our highly classified apparatus captured by the target. When at risk of discovery or when you've successfully completed your mission, bolt back to base. Eco mode lets you conserve battery life as you approach your target while Sports mode kicks it into high gear so you make it back to HQ quickly.
Eco-Mode
Conserve Battery
Sports Mode
Trade off battery for speed
A black toy car with a camera on top.
Light up night missions with LED headlights
Parts of your mission will require clandestine operations at night. To safely navigate the dark and capture clear video, quickly activate and deactivate your headlights from the app. But be cautious! You need to remain undetected.
A small black vehicle with large tires.
2 hours of nonstop action
Don’t worry about getting caught with low fuel during your escape. We’ve packed Wyze Car with a 10,000 mAh power bank that will keep you running throughout your entire mission.
