Wyze Watch 44mm
Wyze Watch 44mm
![Black Wyze Watch 44 Millimeter. Shows black watch band and smart digital interface clock.](http://www.wyze.com/cdn/shop/products/wyze_watch_44mm_1.jpg?v=1645215148&width=1445)
This one is for the movers and the shakers.
Stay unrestricted with a compact 1.44” screen in an aluminum frame so light that you might forget you have it on.
![Wyze Watch 44 with dark green band](http://www.wyze.com/cdn/shop/files/1114wyze_A02_1.png?v=1645215851&width=1500)
A window to better wellness.
In just a few taps, you can check for drops in your blood oxygen saturation - one of the early signs of serious health risks. Also track steps, heart rate, and other fitness information right from your wrist.
![Person holding their wrist up to check messages on their wyze watch 44](http://www.wyze.com/cdn/shop/files/21006_06.23_2.png?v=1645216149&width=1500)
Stay connected to what matters.
Wyze Watch 44mm displays your phone's notifications to save you from digging in your pocket or purse to check a message.
![Person wearing backpack and checking wyze watch 44 on wrist](http://www.wyze.com/cdn/shop/files/h1pYX2Aw_1.png?v=1645216393&width=1500)
Travel without another charger in your bag.
With up to 9 days of battery life, you have one less thing to worry about when you’re heading out on your latest adventure.
![Wyze band and watch showing emails on screen](http://www.wyze.com/cdn/shop/files/Frame_668.png?v=1645216298&width=1500)
See even more than before.
With a high-density square display, you’ll be able to read and see more than you ever could with a fitness band.
1.44-Inch Screen Size
Show off your personal style.
Be bold and make a statement or help your watch blend in. The choice is yours with over 35 customizable watch faces and six 22mm quick-release straps to choose from.
35+ Customizable Watch Faces 6 Quick-Release Straps
![Wyze watch 44 with three different watch bands in brown, green, and rainbow](http://www.wyze.com/cdn/shop/files/Frame_667.png?v=1645216511&width=1500)
![Person washing their hands in a sink with a wyze watch 44 on their wrist](http://www.wyze.com/cdn/shop/files/21006_06.23_042c7ca6-8527-4579-a5be-2e7adc9d5c0d.png?v=1645215968&width=1500)
By your side no matter the conditions.
Dust, rain, or sweat? No problem. IP68 weather and water resistance means there’s no need to worry about the elements - whether you’re out and about or just doing the dishes.
![Black Wyze watch 44 watch face](http://www.wyze.com/cdn/shop/files/image_37.png?v=1645216578&width=1500)
A shortcut to your Wyze Shortcuts.
Control your Wyze devices using the Shortcuts you know and love from the top of your Wyze app. Lights, cams, robot vacuums, and more are at your fingertips.
