NaN of -Infinity
Wyze Light Strip
Wyze Light Strip
Color your world with brilliant LED accent lighting.
Size
Get it as soon as tomorrow Mar 31 to 98033
Order within 15 hours
  • 16 Million Colors
    RGB and tunable white
  • Music Mode
    Sync lights to the beat of the music
  • Sun Match
    Automatically adjust color to match the time of day
  • Trimmable Design
    Cut to fit any space
in app light strip settings
Music Mode makes a rave in every room
Sync your lights to the beat of your favorite tracks with Music Mode using Wyze Light Strips’s built-in microphone. Your dance videos (and dance parties) just got a serious glow-up.
Sun Match
Automatically sync the color temperature of your LED light strips to the natural light-cycle of the day, so you can wake, work, or wind down the way nature intended.
Amazon Alexa sitting on side table
Outside view of house where the lights in each room are a different color
light strip pro lighting up behind a bed
light strip pro in app timer settings
More bright ideas
Make it look like someone's home whenever you are away. Just enable "Vacation Mode" in the Wyze app and our light strip does the rest.
Start a timer to have your strip turn on or off or create powerful automations in the Wyze app.
  • light strip lighting up in purple color
    Wyze Light Strip (Current Page)
    - One color per strip
    - Basic lighting effects
    - No epoxy coating
  • light strip lighting up in rainbow colors
    Wyze Light Strip Pro
    - Up to 16 colors per strip
    - Advanced lighting effects
    - Protective epoxy coating
    - Plus all great features of Wyze Light Strip!
    More Info
