1 of 8
Wyze Light Strip Pro
Customize your vibe with multi-color segment control.
Size
Multi-color segment control
Multiplayer, meet multi-color. Normal LED light strips can only show one color at a time. Ours displays up to 16 RGB colors at once and does advanced lighting effects so you can stack victory royales in the perfect ambiance.
Light strip pro lighting up behind a computer and desk
light strip pro
Segment Control
Wyze Strips Pro has a chip between every 3 LED lights which allows for multiple colors to display at the same time and advanced lighting effects.
light strip pro
Protective Coating
A clear epoxy coating protects the advanced components and provides a refined, flexible appearance.
light strip pro being cut by scissors
Trimmable Design
Designated cut areas allow precise customization to fit your space.
in app light strip settings
Music Mode makes a rave in every room
Sync your lights to the beat of your favorite tracks with Music Mode using Wyze Light Strips’s built-in microphone. Your dance videos (and dance parties) just got a serious glow-up.
Sun Match
Automatically sync the color temperature of your LED light strips to the natural light-cycle of the day, so you can wake, work, or wind down the way nature intended.
Amazon Alexa sitting on side table
Outside view of house where the lights in each room are a different color
light strip pro lighting up behind a bed
light strip pro in app timer settings
More bright ideas
Make it look like someone's home whenever you are away. Just enable "Vacation Mode" in the Wyze app and our light strip does the rest.
Start a timer to have your strip turn on or off or create powerful automations in the Wyze app.
  • light strip lighting up in rainbow colors
    Wyze Light Strip Pro (Current Page)
    - Up to 16 colors per strip
    - Advanced lighting effects
    - Protective epoxy coating
    - Plus all great features of Wyze Light Strip!
  • light strip lighting up in purple color
    Wyze Light Strip
    - One color per strip
    - Basic lighting effects
    - No epoxy coating
    More Info
1 of 2
