Wyze Handheld Vacuum
The perfect spot cleaning companion from car to home.
Engineered for extreme portability.
Wyze Handheld Vacuum was designed to be luxuriously convenient to use for any task. At just 1.23lbs and under 3" thick, it's 50% lighter and 65% more compact than leading handheld vacuums.
Double the suction of other handheld vacs.
Most handheld vacuums (8kPa) can handle dust and small debris. Wyze Handheld Vacuum (16.8kPa) takes portable cleaning to a new level by pulling up even the deepest dirt, crumbs, and pet hair.
USB-C charging.
Charge your vacuum where you charge all your devices with the integrated USB-C port. View your battery life in bright LEDs with up to 30 minutes of run-time.
True HEPA allergen filtration.
To empty, just press a single button located near the nossle. Inside are the dustbin, stainless steel filter, and true HEPA filter which traps 95% of allergens. Each part is easily removable and washable.
Turbo / Eco Mode
Whether you're spot cleaning or rage cleaning, Wyze Handheld Vacuum has a mode for that. Even at its loudest setting, it's still 20% quieter than most handheld vacuums.
Attachments for every clean.
Impossible-to-reach places have finally met their match. Included are 4 unique tools to help you clean even the most awkward of spaces.
