NaN of -Infinity
Wyze Duo Cam Doorbell
Two cameras. Two views. Double the porch protection.
Color
Style
$89.98
$2.99 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Wyze Duo Cam Doorbell is our most advanced battery-powered video doorbell yet. Dual camera views for people and packages, 2K video and local storage, two-way audio, real-time AI detections and alerts, and motion-activated voice deterrence. Includes Wyze Wi-Fi Chime and Wyze Removable Battery Pack. You can enable 24/7 local recording when you add a MicroSD card (sold separately) and set up the doorbell with hardwired power.
  • Two Cameras. Two Views.
    One camera sees people, and another focuses on the doorstep for clearer package detection.
  • 2K HD Resolution + Color Night Vision
    Our award-winning starlight sensor amplifies low light for color images even at night.
  • Wi-Fi Chime Included
    Receive notifications anywhere in your home. Compatible with all Wyze Cams and doorbells.
  • Battery-powered or Hardwired
    Eliminate downtime with a removeable and rechargeable battery that lasts up to 6 months.
Two Cameras. Two Views. Double the Porch Protection.
Some is good. More is better. And Wyze Duo Cam Doorbell with TWO cameras and full porch coverage is the punch that'll send porch pirates packing!
2K Video Resolution with Color Night Vision
Capture all porch arrivals and departures in greater detail. Our award-winning starlight sensor amplifies low light for vivid color images even at night.
Ding dong from anywhere. Hear alerts exactly where you want in your home. Built-in Wi-Fi enables you to trigger audio alerts with all Wyze Cams and Doorbells.
If you are interested in using Duo Cam Doorbell with your existing mechanical or digital chime, check out Wyze Chime Controller for compatibility.
Take your doorbell to the next level with Cam Unlimited.
A Doorbell Cam Built for AI ✨
Person Detection + Facial Recognition 🧑
One camera sees people to clearly capture every visitor. Get next-level notifications with Facial Recognition so you know when it's your best friend or if it's mom.
Learn more
Another camera looks directly down at your doorstep. And we will tell you the moment your latest package of [REDACTED] arrives, but we can't remove the shame of your subscription.
Learn more
Unless your pet is a llama, you know they won’t always show up on your doorbell cam. Now you can spot the furball when they make their way to your front porch. See everything from your door to doormat to doggo.
Learn more
Utilize the top cam to record each vehicle that stops at your residence. You can monitor a delivery driver from the moment they park in front of your house to when they drop off the package.
Learn more
Easy 1-Minute Install
Mount it in two shakes of a dog's tail with the included adhesive strips. No wires or screws. I'm paw-sitively certain you'll have it up in no time. You can also wire it if you really want to.
Two-Way Audio
Act like a celestial messenger who knows neither time nor space and answer your door from anywhere. Somehow "Please leave my curly fries right there" feels more dignified when replying via the Wyze app.
IP65 Weather Resistant
It's rated to withstand all the elements. Even the element of surprise. In fact, it's basically impossible to sneak up on this thing. Did we mention it has TWO cameras?
Local Recording with microSD
See what happened start to finish with local recording. MicroSD card sold separately.
⚠️ To enable 24/7 local recording you must add a microSD card and hardwire the doorbell cam.
  • Dual-Band Wi-Fi
    Connects to 2.4 GHz or 5 GHz Wi-Fi networks.
  • Motion & Sound Notifications
    Get instant notifications sent to your phone for any visitor or package delivery.
  • 30° Corner Kit Included
    An angled mounting wedge is included with every doorbell to help you achieve the perfect view.
  • Alexa, Google Assistant, IFTTT Support
    Works with your favorite smart assistant. Use Wyze Automations for more control.
NaN of -Infinity
  • Duo Cam Doorbell NEW
    FOV: Top: 132 x 100° / Bottom: 121 x 60°
    Resolution: Top: 2K / Bottom: 1080p
    Compatible Chime: Wyze Wi-Fi Chime or Wyze Chime Controller
    Installation: 3M adhesive or screw mounting
    Local Storage: Supports up to 256 GB, 24/7 continuous recording is available when hardwired
    Mounting Location: Anywhere
    Power: Wyze Removable Battery Pack or Wired (AC 16-24 V)
  • Video Doorbell Pro
    FOV: 150 x 150°
    Resolution: 1440p+
    Compatible Chime: Wyze Chime Pro (no longer available for sale)
    Local Storage: N/A
    Power: Rechargeable Built-In Battery or Wired (AC 16-24 V)
  • Video Doorbell v2
    FOV: 135 x 103°
    Resolution: 2K
    Compatible Chime: Existing mechanical chime (with Wyze Chime Controller)
    Installation: Screw mounting
    Mounting Location: Requires existing wiring
    Power: Wired (AC 16-24 V) only
NaN of -Infinity
