1 of 9
Wyze Cam Outdoor v1
Wyze Cam Outdoor v1
Move it, mount it, record it - anywhere. Wireless.
Check out the newer model:
  • 2.5K HD w/Color Night Vision.
  • Built-in spotlight.
  • Removable battery.
  • Doesn't need a base staton to work.
  • Indoor/Outdoor friendly.
  • More processing power. It's faster!
  • Works with Wyze Solar Panel
  • You'll also continue to get the amazing features of Wyze Cam Outdoor: 2-way audio, built-in MicroSD slot and traditional night vision.
Get Battery Cam Pro
Style
Item is no longer available.
Stand up to any weather.
Stand up to any weather. IP65 weather-resistant. Bring on the downpours, blizzards, and heatwaves- Wyze Cam Outdoor is built from the ground up to be a workhorse in even the harshest conditions.
WCO mounted on house
Wireless. Go where wire’s can’t.
Wire-free & battery powered. Mount to the outside of your home or in your trees without running wire or searching for outlets. 2x 2,600 mAh integrated rechargeable batteries last from 3-6 months based on normal usage.*
*Normal usage is 10-20 event videos per day. Battery life varies based on settings, temperature, and usage.
Seize the day. Illuminate the night.
1080p Full HD with nightvision. Crisp video recording and live streaming with 25 ft, yard-illuminating night vision lets you see every detail on a face or whisker on a snout.
See who’s coming and going.
Wyze Cam Outdoor uses passive infrared sensors (PIR) to sense body heat signatures which reduces false alerts from things like waving branches and falling leaves. When motion is detected, you’ll get an alert from the Wyze app so you never miss a thing.
house signal illustration
Cover every corner of your home.
Low profile base station. Connect up to 4 cameras to a single bay station and view all video streams in the Wyze app. The starter bundle includes one Base Station. (Additional cameras sold separately and available at general launch.)
WCO
WCO
illustration of wco coverage
2 way audio with delivery
Respond in real time.
Two way audio. Ask the delivery person to hide a package behind the bushes, or scare off unwanted guests in your yard using Wyze Cam Outdoor’s built-in speaker and microphone.
wco picture in mountains
Capture the world
Offline video recording. Staying at a hotel or backpacking in the Rockies? Travel Mode records motion & time-lapse videos locally to a MicroSD card for when you’re without an internet connection or base station.
Timelapse
Pikes Place 2019
Experiences
Mountain Rainier 2019
Behind the scenes
Set up and installation made easy.
