You might also be interested in
Say goodbye to the complexity and cost of installing a junction box. Go with an easy, plug-n-play floodlight solution instead. Bundle comes with both Wyze Cam Floodlight Pro and Plug-in Mount in white.
Bundles comes with Wyze Cam Floodlight Pro
Professional yard security to brighten any space.
A category-leading pro floodlight with 180° field-of-view means you can protect your property with fewer blind spots.
It offers 2K HD resolution for clear color night vision. With three adjustable light panels, its 3000-lumen LEDs deter intruders and reveal details even in the dark.
Connect with dual-band (2.4 and 5.0 GHz) Wi-Fi compatibility.
Also included, Plug-in Mount
Easy to install. No junction box needed.
Say goodbye to the complexity and cost of a junction box. No need to hire electricians and handy people, or cut giant holes into the exterior of your home.
A flexible power solution for all Wyze Cam Floodlights.
Ditch the shock and zap (unless you're into that sort of thing). If you can plug in a cable, then you can enjoy the security of a Wyze Floodlight. No more scary junction boxes and expensive electricians.
The Perfect No Hassle Combo
Put it right where you need it.
Free thyself from the shackles of non-ideally-located junction boxes! The durable 20ft. cable reaches outdoor-rated outlets with ease. A velcro strap is included for clean cable management.
