Wyze Buds
Wyze Buds
Your body-rocking audio partner from home to gym.
![Black Wyze Buds](http://www.wyze.com/cdn/shop/products/WyzeBuds.png?v=1644343932&width=1445)
![Wyze Buds](http://www.wyze.com/cdn/shop/files/WyzeBudsMain-02.jpg?v=1683064244&width=1445)
![Wyze Buds](http://www.wyze.com/cdn/shop/files/WyzeBudsMain-03.jpg?v=1683064254&width=1445)
![Wyze Buds](http://www.wyze.com/cdn/shop/files/WyzeBudsMain-04.jpg?v=1683064257&width=1445)
![Wyze Buds](http://www.wyze.com/cdn/shop/files/WyzeBudsMain-05.jpg?v=1683064263&width=1445)
![Wyze Buds](http://www.wyze.com/cdn/shop/files/WyzeBudsMain-06.jpg?v=1683064266&width=1445)
![wyze buds sound](http://www.wyze.com/cdn/shop/files/WyzeBuds_BannerImage.jpg?v=1645161613&width=1500)
10.5mm audio drivers deliver bone-rocking bass from lace up to cool down.
Wyze buds are engineered to deliver an intensified, bass-driven sound to help propel you toward your fitness goals.
![Illustration of person wearing Wyze buds](http://www.wyze.com/cdn/shop/files/img_reduction.png?v=1645162743&width=1500)
![Wyze buds silicon tips](http://www.wyze.com/cdn/shop/files/WyzeBuds_SmallBannerImage.jpg?v=1645161613&width=1500)
Choose the perfect fit so you can keep moving.
Up to 27 hours of charge. Guaranteed to outlast almost any workout.
With up to 7 hours on a single charge plus 20 hours in the case you get battery life so long your play button might get tired.
![Wyze Buds case and ear buds laying on ground.](http://www.wyze.com/cdn/shop/files/21013_BudBasic_07.26.21_HiRes-2159.jpg?v=1678806356&width=1500)
4.8 grams of lighter-than-air comfort.
These truly wireless earbuds offer a comfortable, barely-there feel and a low-profile design that isn’t desperate for attention.
![Person touching Wyze buds in their ear with their finger to use touch controls](http://www.wyze.com/cdn/shop/files/21013_BudBasic_07.26.21_HiRes-1761.jpg?v=1678806498&width=1500)
Keep moving with phone-free touch controls.
Keep the interruptions to a minimum with customized smart touch controls that don't skip a beat. Tap twice to play/pause. Tap three times to activate the voice assistant.
![Person exercising while wearing Wyze buds and sweating.](http://www.wyze.com/cdn/shop/files/img_carousel_3.png?v=1645163502&width=1500)
![Person holding phone looking at Wyze buds in the Wyze app](http://www.wyze.com/cdn/shop/files/WyzeBuds_Accordion_2.jpg?v=1645161613&width=1500)
![Person wearing wyze buds pro with their finger against the side to engage virtual assistant](http://www.wyze.com/cdn/shop/files/WyzeBuds_Accordion_3.jpg?v=1645161613&width=1500)
![Person touching Wyze buds in their ear with their finger to use Alexa built in.](http://www.wyze.com/cdn/shop/files/WyzeBuds_Accordion_4.jpg?v=1645161613&width=1500)
More smart features. Wear detection for hassle-free stops and starts
An embedded sensor auto-detects when it’s in your ear and knows what to do when it’s not.
IPX5-rated moisture resistance can withstand sustained perspiration from crossfit to marathons and everything in between.
Tune Wyze Buds to your liking by adjusting the equalizer in the Wyze app. Create and save your own custom preferences or choose selections that are optimized for music, movies, voices, gaming, and more.
A 4-microphone system let's you hear the world around you with a simple touch.
Instantly connect to Amazon Alexa to play your favorite music, check the weather, get news, and more. Wyze Buds are also compatible with your phone’s native smart assistant (Siri, Bixby, Google Assistant).
* Optimized for Android. iOS requires the Alexa app in the background.
Wyze Buds
-30 dB passive noise reduction
-Up to 27 hrs of battery life
-4-microphone system
