1 of 1
Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle
Color your world with brilliant LED accent lighting.
What's in this bundle
Wyze Bulb Color (Style)
Wyze Light Strip Pro (Size)
OR
$66.99 $74.97
Select a 2 or 4 pack
Wyze Bulb Color - Smart E12 Bulb
We didn’t just make another color light bulb. We made a bulb that enhances the way you live each moment. A bulb gives you a full complement of colors (16 million to be exact) and controls to turn moments into memories.
Select a 16 or 32 feet length
Trim to any length that you need and adhere it on walls, desks, and more. The Wyze LED Light Strip Pro can seamlessly combine with Wyze bulbs, allowing simultaneous control via the Wyze app.
Create vivid, dynamic lighting scenes effortlessly, tailoring the ambiance to your preferences.
  • 16 million colors 🌈
    Whether it’s game day or wine night, precise color control in the Wyze app lets you turn moments into memories.
  • Brilliant notifications 💡
    Create time-based color events or automate using other Wyze devices to create powerful visual notifications.
  • Dance to the beat of the music 🕺
    Group your Wyze Bulb with Wyze Light Strip to sync your lights to the beat of your favorite tracks with Music Mode.
  • Did you forget to shut your door? 🤦
    Trigger a warning with Wyze Color Bulb and Wyze Sense Motion Sensors or Entry Sensors.
  • Vacation Mode 🏝️
    Make it look like someone's home whenever you're away. Enable "Vacation Mode" in the Wyze app and our bulb does the rest.
  • Voice Control 🗣️
    Command your lights with your voice by asking Alexa or Google Assistant to turn them on/off, change color, and more.
1 of 6
In-app light control
Wyze App (Android & iOS)
Light color controls and so much more...
Cool it down and focus or warm it up and relax. Dedicated white light controls let you choose the perfect setting for your activity.
Do everything you need in one powerful Wyze app.
