Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle
Color your world with brilliant LED accent lighting.
- 1x Wyze Bulb Color 2 pk or 4pk
- 1x Wyze Light Strip Pro
Select a 2 or 4 pack
Wyze Bulb Color - Smart E12 Bulb
We didn’t just make another color light bulb. We made a bulb that enhances the way you live each moment. A bulb gives you a full complement of colors (16 million to be exact) and controls to turn moments into memories.
Select a 16 or 32 feet length
Trim to any length that you need and adhere it on walls, desks, and more. The Wyze LED Light Strip Pro can seamlessly combine with Wyze bulbs, allowing simultaneous control via the Wyze app.
Create vivid, dynamic lighting scenes effortlessly, tailoring the ambiance to your preferences.
Wyze App (Android & iOS)
Light color controls and so much more...
Cool it down and focus or warm it up and relax. Dedicated white light controls let you choose the perfect setting for your activity.
Do everything you need in one powerful Wyze app.
