1 of 6
Wyze Lamp Socket Bundle
Make your exterior lighting smart. Power Wyze Cam v3 without a plug.
Bundle
Flexible power for your Wyze Cam v3/v4
Skip the wiring and electrocution (unless you're into that sort of thing). Harness the electricity from your outdoor light fixture to continously power your Wyze Cam v3/v4. No more creative cord compositions. No long, ugly wires. No hassle.
Wyze Lamp Socket powering an Edison bulb outside with a Wyze Cam v3 attached to the outlet built into the socket.
A Wyze Lamp Socket with an Edison bulb attached
Upgrade to smart lighting in seconds.
Wyze Lamp Socket and Wyze Cam v3 work together to make your existing outdoor lighting smart. The socket gives the camera power and the camera gives the socket brains! A perfect, symbiotic relationship, just like Hippo and Oxpecker! Sing it with us! Symbiotic! Symbiotic!
Illuminate your way to motion activated lights.
Set your newly smartened lights to illuminate whenever Wyze Cam v3/v4 senses motion or sound. Now your old light fixture is a cutting-edge model of sleek security sophistication!
Easily link multiple sockets for greater coverage and control.
Auto-connect up to 5 lamp sockets for Olympics-worthy synchronization of your outdoor lighting. Then schedule and control your newly smart setup from anywhere using the Wyze app.
Dusk to Dawn Automation.
Get Inspired
See how Wyze users are using their Wyze Lamp Socket!
As easy as screwing in a light bulb.
Some installations are as easy as screwing in a lightbulb. Other installations are literally the exact same as screwing in a lightbulb. Wyze Lamp Socket falls in the latter category.
