Smart Lighting Kit - Bulb Color BR30 + Light Strip Pro Bundle
- 1x Wyze Bulb Color BR30
- 1x Wyze Light Strip Pro
Color your world with brilliant LED accent lighting.
Select a 2 or 4 pack
Based on the same magical greatness that made our original Bulb Color perfect but now in the BR30 bulb shape. A bulb gives you a full complement of colors (16 million to be exact) and made to fit like a glove with your recessed lighting. Control these lights from the same app too.
Select a 16 or 32 feet length
Trim to any length that you need and adhere it on walls, desks, and more. The Wyze LED Light Strip Pro can seamlessly combine with Wyze bulbs, allowing simultaneous control via the Wyze app.
Create vivid, dynamic lighting scenes effortlessly, tailoring the ambiance to your preferences.
Wyze App (Android & iOS)
Light color controls and so much more...
Cool it down and focus or warm it up and relax. Dedicated white light controls let you choose the perfect setting for your activity.
Do everything you need in one powerful Wyze app.
