Skip to content
SAVE UP TO 30%
Gear up for Spring!
Now's the time to stock up on Wyze Cam OGs, Battery Cam Pro, and Floodlights. Light up Spring and Summer nights with some of our brightest cams.
Only while supplies last. Ends 04/28/24.
Wyze Cash on your next order
Get Wyze Cash when you spend over $50 on your order. Shop like you normally do, checkout through our store, and we'll send you Wyze Cash in an email once your order ships. It's that easy!
Learn more in our terms and conditions.
Limited-time offer
Get Cam OG for $19.98
  • Comes with a built-in spotlight, siren, and designed for stacking 🔥
    Capture the big picture with a 120° field of view and built-in spotlight.
    Shop now
  • The best solution for when you need hawk-eye vision to see veeery far away 🔭
    Capture the little things with 3x zoom. That's right, now you can capture the fine details that matter.
    Shop now
Now's the time to grab the Stack Kit Bundle
Get both Cam OG (standard) and Cam OG Telephoto and the stack kit. 2 cameras. 2 views. 1 clean setup that runs off a single power supply unit.
Single product image of Floodlight Pro
WYZE CAM FLOODLIGHT PRO
Save $50
Now only $99.98
(regular price $149.98)
Designed with 180° wide-angle lens and 2.5K QHD video so you can see your yard end-to-end. Fast onboard AI computer vision. 3,000 lumen LED lights.
Shop now
Wyze Cam Floodlight v2
Over 30% off
Now only $59.98
(regular price $89.98)
Dominate the dark with 2800 Lumens LEDs, 2K video with Color Night Vision, and a 160° wide-angle view. Enjoy 24/7 local recording, two-way talk, and more.
Shop now
