1 of 5
Wyze Outdoor Power Adapter
Ready for rain, snow, or shine. IP67 weather resistant so you can safely use your Wyze Camera outdoors.
⚠️ The Outdoor Power Adapter works with Wyze Cam v4 or OG series. It is also compatible with Cam Pan v3 or Cam v3 Pro, when paired with L-shaped Adapter.
Style
Low stock: 52 left
Ready for rain, snow, or shine. IP67 weather-resistant so you can safely use your Wyze Camera outdoors.
Note: Wyze Cam v3 Pro and Pan v3 requires both the Outdoor Power Adapter and L-shaped MicroUSB Adapter. Wyze Battery Cam Pro requires both Outdoor Power Adapter and USB-C adapter. Adapters will NOT work with OG Stack Kit.
