1 of 7
Wyze Switch
Wyze Switch
Control lights and other Wyze devices with just a press.
Size
OR
Turn normal lights into smart lights and control them from anywhere. Multi-tap to control other Wyze devices like Wyze Cams, Wyze Lock, and Wyze Robot Vacuum.
All your lights just got smarter.
Upgrade to smart lighting in any room with Wyze Switch, a smart, WiFi light switch. Control your lights from anywhere with the Wyze app and create automations that bring light to your life.
wyze switch in app
wyze switch in app
Take control of your smart home ecosystem.
Wyze Switch integrates seamlessly with your Wyze ecosystem with four custom actions. Personalize each action to fit your life: Single-press to turn on the lights, double-press to lock the doors, triple-press to turn on the robot vacuum, and press-and-hold to spray unwanted guests with Wyze Sprinkler Controller.
sleeping person with lights on in room
Outdoor view of house with pool. All indoor and outdoor lights are turned on
wyze switch on wall outside bedroom door
Smart controls you would expect.
Create powerful automations in the Wyze app or set a timer to have your lights turn on or off.
Make it look like someone's home whenever you are away. Just enable Vacation Mode in the Wyze app and our switch does the rest.
If there is a power loss, Wyze Switch will automatically reconnect to Wi-Fi and return to its previous state, once power is restored.
It’s easy to install Wyze Light Switch.
