Capture every moment. No blind spots with Wyze Cam Pan v3.
The Wyze app enables you to have a quick view of all your cameras' live feeds in one place. Scroll through events recordings and play back anything you've missed.
- Say "hi!" with two-way audio
- Pan 360° and tilt 180°
- Color night vision
Track who comes and goes... even the dog walker.
Control your Lock right from your phone—no matter where you are. Unlock the door for the dog walker or give them their own code.
Eliminate odors and reduce dander with Wyze Air Purifier
Loving our fur best friends can come with some unfortunate side-effects. Keep your space smelling fresh and reduce the amount of dander you take in with any given breath.
Catch the , everyday moments of your pets.
We know you love your furbabies, having the ability to watch and communicate with them is essential to keeping them safe. And gives you peace of mind. But let's be honest, sometimes we just need to tell them to behave.
Convenience in one app
Access the power of the Wyze app. Super-duper functionality and it's free. Unlock even more functionality with by adding one of services plans.
Quickly view all your cameras' live feeds in one place and scroll through motion-activated event recordings.
It can be hard to leave our pets. With two-way audio built into our cameras you can say "hello!" and customize how you want to be notified when motion or sound is detected.
Access the latest features of Wyze AI with a subscription to Cam Plus (or Cam Protect). Sound detection is a beta feature that can tell the difference between crying, meowing, barking, and talking.
It is currently available as part of the Beta Program. Learn more about the program here.
Friend stopping by to check up on the pups and need access to the back door? Need the dog walker to have access while you're at work? No problem. Quickly share and revoke access to your Wyze Lock or Lock Bolt at any time.
Share unique codes to know exactly who's been coming and going.
Hear it from other Pet Parents who use Wyze.
Products for every day needs.
Frequently Asked Questions
While we recommend Cam Plus for access to smart detections and notications, it's not required. You can still access live feeds with a free account and use a microSD card for video recordings and image captures.
While a single Wyze Cam Pan v3 could manage the monitoring of a single space well, most cameras have limitations when trying to track multiple pets. We often suggest a cam per room and hallway.
- Log in to your Wyze app to set up your Wyze devices.
- Activate & set up your Wyze Cam in your Wyze account.
- Create a schedule within Wyze app to trigger motion detection notifications while you are away from home. Tap Home > + plus sign on the top left >Add Rule >Schedule
- Set the Action to send your desired type of alert when motion is detected.
- Set the time for the Rule to be active.
- Tap Save.
You will need a Cam Plus or Cam Protect subscription enabled on your Wyze Cam to set up alerts for pet sounds like barks & meows.
