Wyze Band Warnings and Instructions for Use
Wyze Wearables Warnings and Instructions
Effective: January 6, 2022
IMPORTANT SAFETY WARNINGS
READ AND UNDERSTAND ALL INSTRUCTIONS AND WARNINGS BEFORE USING ANY WEARABLE WYZE DEVICE, INCLUDING WYZE BAND AND WYZE WATCH (BOTH THE 44 MM AND 47 MM VERSIONS). FAILURE TO FOLLOW THESE SAFETY INSTRUCTIONS COULD RESULT IN SERIOUS PERSONAL INJURY, DEATH, OR DAMAGE TO THE PRODUCT OR NEARBY PROPERTY.
Not a medical device.Your Wyze device is not a medical device and is not intended to diagnose, treat, cure, or prevent any disease or medical condition. Consult your doctor before beginning any exercise program. If you experience an emergency, call 911. As discussed below, Wyze does not monitor your vitals, call 911, or dispatch other emergency services.
Consult your doctor before using if you have a pacemaker or other implanted medical device.The wearable Wyze device emits electromagnetic fields that could interfere with pacemakers or other implanted medical devices. Interference with a pacemaker or other implanted medical device could cause the device to malfunction and result in serious personal injury or death.
Consult with your doctor before using the heart rate tracking function if you have a history of seizures and/or photosensitivity.Your wearable Wyze device tracks your heart rate by emitting flashes of green and infrared light. Some people may experience a seizure when exposed to certain visual images, including flashing lights or patterns—even people who have no history of seizures. Seizures can cause lightheadedness, confusion, jerking or shaking, and/or loss of consciousness, which can result in serious personal injury, death, or damage to nearby property. Consult with your doctor before using this feature if you have epilepsy or are sensitive to bright or flashing lights or are taking any medications that can cause photosensitivity.
Consult your doctor before using if you have any musculoskeletal disorders, circulation issues, or other medical issues affecting your hands or wrists.If you bruise easily or have reduced circulation, carpal tunnel syndrome, hand/wrist tendonitis, or other musculoskeletal disorders, consult your doctor before wearing a Wyze device. Using a wearable Wyze device may exacerbate these conditions.
Do not wear your wearable Wyze device too tight.Your wearable Wyze device should fit snugly around your wrist, but not so tight that it restricts blood flow. Wearing your Wyze device too tight can interrupt blood flow to your wrist and hand. If you feel numbness, tingling, burning, or stiffness in your arm, hand, or wrist, loosen your Wyze device or take it off immediately. If any of these symptoms last more than 2 days, see a doctor immediately.
Stop use immediately if the Wyze device feels hot.If your Wyze device becomes hot take it off and discontinue use immediately. Failure to take off the device when it gets hot can result in burns.
Stop using the Wyze device immediately if any part is damaged.Inspect the device and USB charging cable regularly. If you suspect any part is damaged, discontinue use immediately. Continuing to use the device and USB charging cable if any part is damaged may cause overheating, fire, explosion, electric shock, or smoking, which could result in serious personal injury or death. It could also result in additional damage to the device, USB charging cable, or other nearby property.
Do not burn, break, gouge, puncture, crush, drop, or otherwise damage the device or USB charging cable.Damaging the device or USB charging cable may cause overheating, fire, explosion, electric shock, or smoking, which could result in serious personal injury or death. It could also cause additional damage to the device, USB charging cable, or other nearby property.
Use only the USB charging cable provided to charge your Wyze device.Do not use any other USB charging cable to charge your Wyze device. Use of another USB charging cable may lead the product to overheat or catch fire, which could result in serious personal injury, death, or damage to nearby property.
Do not charge your Wyze device while wearing it.Take your Wyze device off before charging it. While it is charging, parts of your Wyze device may become warm or hot. As a result, wearing the Wyze device while charging it can result in burns. For the same reason you should use caution when touching the Wyze device or USB charging cable while it is charging.
Do not leave the Wyze device or USB charging cable near heat sources or places where heat collects.The Wyze device and USB charging cable should not be placed in direct sunlight, near heat sources (e.g., fireplaces, portable or baseboard heaters), or other areas where heat collects. Ensure that the Wyze device and USB charging cable are used, charged, and stored in cool areas with adequate ventilation. Specifically, the wearable Wyze devices and USB charging cable should not be used in environments hotter than 113°F or cooler than 32°F. Allowing the Wyze device and USB charging cable to become too hot may cause overheating, fire, explosion, electric shock, or smoking, which could result in serious personal injury or death. It could also result in damage to the Wyze device, USB charging cable, or other nearby property.
Charge your Wyze devices indoors only.Only the wearable Wyze device itself is water resistant. The USB charging cable is not waterproof. Do not get it wet. Do not charge your Wyze device in a room with more than 90 percent humidity. Do not charge your Wyze device if it is wet or damp. Do not handle your Wyze device or USB charging cable with wet hands while charging. Charging your Wyze device while it is wet or in a room with more than 90 percent humidity, may result in electric shock, fire, explosion, or smoking, which could result in serious personal injury or death. It could also result in damage to the Wyze device, USB charging cable, or other nearby property.
Do not get the USB charging cable wet.Unlike the wearable Wyze device itself, the USB charging cable is not water resistant. Do not get it wet. Clean only with a dry cloth. Charge your Wyze device in a cool, dry place. Do not touch the USB charging cable or Wyze device with wet hands while charging. Getting the USB charging cable wet may result in electric shock, fire, explosion, or smoking, which could result in serious personal injury or death. It could also result in damage to the Wyze device, USB charging cable, or other nearby property.
Keep the Wyze device and all its components out of reach of children and pets.The Wyze device is not a toy. Never allow children to play with the Wyze device or USB charging cable. The Wyze device contains small parts that may present a choking hazard. Allowing children to access or play with the Wyze device could result in serious personal injury to or death of the child. Failure to keep pets away from the Wyze device could result in serious injury to the pet.
Keep cords out of reach of children.Children can get tangled in charging cords, risking serious personal injury or death by strangulation. Place cords at least three feet away from any crib, bassinet, play yard, or other safe sleep environment.
Do not attempt to remove, repair, or modify any part.The Wyze device and USB charging cable do not contain any user-serviceable parts. Do not open them. The Wyze device is not designed to be opened. If you attempt to open the Wyze device, you could receive an electric shock. You could also damage the Wyze device’s components, which could result in overheating, fire, explosion, electric shock, or smoking, which could result in serious personal injury or death. It could also result in damage to the Wyze device, USB charging cable, or other nearby property.
CONTAINS A LITHIUM ION BATTERY
Do not improperly dispose or discard. Lithium-ion batteries should be recycled. To support your ability to recycle locally, Wyze participates in the Call2Recycle industry steward program. To find a Call2Recycle location near you where you can drop your battery powered Wyze product off for recycling, visit the Call2Recycle.org drop-off locator if you are in the United States and the Call2Recycle.ca drop-off locator if you are in Canada.
NOT A SAFETY, SECURITY OR EMERGENCY DEVICE
If you experience an emergency, call 911; Wyze will not do it for you.Wyze does not monitor your vitals or dispatch emergency services to you in the event of an emergency. If you experience an emergency, call 911. Wyze will not do it for you.
