SAVE $
Wyze Smart Home Starter Pack
$99.00
Price includes shipping. Save $10 for a limited time.
The Wyze Smart Home Starter Pack is the easiest and most affordable way to automate your home — whether you want to monitor your front door for deliveries with Wyze Cam or turn on your living room lights with Wyze Plug, this pack has everything you need to transform your home into a smart home. The best part is that everything in this pack is super simple to set up and use, and everything works together seamlessly in the Wyze app. All products in the Starter Pack work with Alexa, IFTTT, and Google Assistant.
Wyze Cam
Wyze Cam lets you keep an eye on things from anywhere with your phone. It automatically records a 12 second alert video when it detects motion, sound, smoke alarm, or carbon monoxide alarm. These videos are accessible for up to 14 days - no subscription required! Learn more
Wyze Bulb
Our affordable smart lighting option that can turn your living room lamp into a smart lamp. Wyze Bulbs can change color temperature from bright daylight to warm reading light, turn on at specific times of day with scheduling, or dim from bright light to low light at the tap of a button in the Wyze app. Learn more
Wyze Plug
Wyze Plug lets you turn any small appliance into a smart appliance. Schedule your air purifier to turn on every morning and run for two hours before turning off or turn off your space heater remotely using the Wyze app so you don’t accidentally leave anything running while you’re away from home. Learn more
Wyze Sense
Our contact and motion sensors let you know when motion has been detected or when a door has been opened or closed. Pair Wyze Sense with other products in the pack to automate actions like turning on the Wyze Plug when motion has been sensed. Learn more
What's in the box
  • 1 x Wyze Cam
  • 3 x Wyze Bulbs
  • 2 x Wyze Plugs
  • 1 x Wyze Sense Starter Kit
  • 1 x SD Card
