Facebook Pixel
  • Hybrid Active Noise Cancellation
    40dB quick on/off hybrid active noise cancellation with Transparency Mode to amplify outside sound.
  • Fatigue-Free Fit
    20mm foam and elongated earpads make for all day comfort.
  • Voice-Isolating Microphones
    Dedicated microphones isolate your voice in a room full of chatter.
  • Wireless, 20-Hour Battery Life
    20 hours of music or calls on a single charge. 10-minute quick charge provides 4 hours of battery.
  • Alexa Built-In
    Access information quickly by asking Alexa or using your phone’s native voice assistant.
See how real people react to Wyze Headphones
You'll think the rest of the world is standing still.
40dB Quick On/Off Hybrid Active Noise Cancellation (ANC).
Equipped with four noise-cancelling microphones and an ultra-fast processor, outside noise is reduced to a whisper so you can stay focused while the world buzzes around you.
Hearing is believing. Listen for yourself.
Listen to actual audio as heard by Wyze Headphones.
We hooked Wyze Headphones up to a pair of binaural microphones so you can hear exactly what they hear. Try it out for yourself.
  • Sound Off
  • Active Noise Cancellation Off
  • Active Noise Cancellation on
For when you want to break the silence
  • Transparency mode
    Outside sounds are amplified through your headphones at the touch of a button so you can listen for your coffee order while enjoying music.
  • Wear detection
    Audio automatically pauses when your headphones are removed and resumes when they’re put back on saving you battery and your spot in the song.
  • Quick conversations
    Gently touching your right earcup pauses audio and enables Transparency mode allowing you to join a conversation at a moment’s notice without taking your headphones off.
Like a symphony playing just for you
Wyze Headphones deliver an unrivaled audio experience combining world-class engineering with premium hardware typically only reserved for “top shelf” brands. Every pair is precision-tuned using leading-edge audio equipment and proprietary AI algorithms.
Wyze Headphones deliver an unrivaled audio experience combining world-class engineering with premium hardware typically only reserved for “top shelf” brands. Every pair is precision tuned using leading edge audio equipment and proprietary AI algorithms.
High-resolution audio
Dual TPU Composite Diaphragm Driver
AKA: These headphones mean business.
Deep bass, stable mids, and crisp highs brought to you by
dual 40mm drivers and a range of frequencies up to 38kHz transport you to the front row of your favorite concert.
Your perfect listening experience lies within the Wyze app
Tune Wyze Headphones to your liking by adjusting the equalizer in the Wyze app. Create and save your own custom preferences or choose premade selections that optimize for music, movies, voices, gaming, and more.
So comfortable you might forget you are wearing them.
Fatigue-free fit. Responsive memory foam and elongated earpads delicately embrace the ear for a superior fit keeping music where it belongs: between your ears and the headphones.
20mm memory foam & elongated earcups. Responsive memory foam and elongated earcups delicately embrace the ear for a superior fit keeping music where it belongs: between your ears and the headphones .
Access music, weather, and more with voice assistants
Use Amazon Alexa built-in or your device’s native voice assistant (Siri, Google Assistant, Bixby).
Leave your phone in your pocket and ask Alexa or your phone’s native voice assistant to access information, set reminders, play music, and more all with your voice.
Intuitive touch and tap sensors put you in control
With both buttons and touch controls. Use the controls located on your headphones to answer calls, adjust volume, activate your voice assistant, or pause/play/ and skip tracks.
For more details, including our FAQ, see our Product Details section.
