Touch-free readings
Don’t worry about cleaning your thermometer between uses: no-touch thermometers can be used on multiple family members without the need for washing.
This item has been sourced in response to the COVID-19 pandemic and is one of our many efforts to help support our community during this time. Learn More
iHealth
Ships within 1-3 business days of ordering
Quickly take the temperature of everyone in your family with results that are delivered in seconds, not minutes.
An ultra-sensitive infrared sensor measures IR energy emitted from the forehead and collects more than 100 data points per second. Distance and environmental sensors make necessary adjustments to give you accurate readings.
To take a temperature reading, hold the thermometer 1 inch from the center of the forehead and press the power button once. When the results are ready (1 second), the thermometer will quietly vibrate.
If you’re taking the temperature of children while they’re asleep, don’t worry about turning on the lights. A large backlit LED lights up the results.
No. This product is made by iHealth, a partner of Wyze.
Yes. Wyze will offer its normal 1-year limited manufacturer’s warranty on this product. For more information on warranty and returns for the iHealth Thermometer, go here.
Yes. For information on how to change the unit of measure, see the support article on this topic.
This thermometer has a +/- 0.4 degrees Fahrenheit. No-touch infrared thermometers, in general, are less accurate than traditional touch thermometers. Often, inaccuracy is caused by incorrect use when measuring. Position, activity level, and even timing can be factors in getting accurate measurements.
Learn more about getting consistent measurements in our support article here.
You can learn more about the correct measurement range for this thermometer on iHealth’s website.
1. Tap the thermometer measurement button once to turn it on.
2. Aim the thermometer probe at the center of the forehead from less than 1.18 in (3cm) away (do not make contact with the forehead).
3. Gently press and hold the measurement button to begin the test.
4. The thermometer will vibrate noiselessly once the reading is complete.
Yes. iHealth PT3 is not harmful to children or adults.
The iHealth PT3 Thermometer is only designed to test temperature on the human body with the measurement being taken at the center of the forehead from less than 1.18 in (3cm) away. Anything else will result in inaccurate temperature measurements.
Position, activity level, and even timing can be factors.
Here is an article we put together with a few tips to ensure the most accurate measurements
We have a full support section for help with the iHealth PT3 Thermometer. Check it out here.
If you need general support or troubleshooting for your iHealth PT3 Thermometer, reach out to our team here: Wyze Support
You can also visit the iHealth support site for help articles, troubleshooting, and more at https://ihealthlabs.com/support/.
