1 of 5
Wyze Cam Spotlight Bundle
Make your next home security camera shine.
$24.98 $49.98
Headlamps! They're not just for spelunkers and middle-aged joggers, folks. They're for Wyze Cam v3! And who's to say Wyze Cam v3 isn't a spelunking forty-something who likes to jog. Did you even bother to ask? Do you even care? No. You just want your precious stuff watched. Well, fine. Wyze Cam v3 can watch it even better with this state-of-the-art, motion-activated, IP65 rated headlamp.
  • A colorful logo of a bird with a rainbow background.
    1080p Color Night Viewing
    See more clearly at night in full color.
  • A sun and clouds icon.
    Indoor/Outdoor
    Capture moments indoors and outdoors with IP65 weather resistance.
  • A sun icon with a black background.
    Smart LED Spotlight
    Light up the dark using Wyze Rules like triggers and schedules.
  • A blue and purple circle with a white cross in the middle.
    See more with Cam Plus
    Unlimited video length storage and advanced AI detection (with subscription).
Wyze Cam v3 Device Details
Color
  • Camera: White with black accents
  • Spotlight: White
Materials
  • Body and Spotlight: Polycarbonate
  • Lens: Glass + Plastic
Camera Dimensions
  • Camera: 52 mm x 51 mm x 58.5 mm
  • Spotlight: 21.5 mm x 55.8 mm x 34.4 mm
Camera Weight
  • Camera: 98.8g
  • Spotlight: 37.5g
Phone Compatibility
  • Android 5.0+
  • iOS 9.0+
Display
  • Resolution: 1920x1080p Full HD
  • Viewing angle: 120º diagonal
Night Vision
  • IR Lights: 4 x940 nm, 4 x 850 nm
  • Day/Night Vision
Audio
  • Mic: ECM
  • Speaker: 80 dB, waterproof
  • Simultaneous 2-way Talk
  • Siren
Power
  • Power Adapter: Indoor 5V/1A
  • Outdoor Power Adapter (sold separately)
  • Cable: 6 ft Flat micro USB Cable and micro USB Cable Splitter
Sensor
  • CMOS Starlight Sensor
LED Indicator
  • Front of camera. Red + Blue.
Spotlight
  • Brightness: 70 lumens
  • Temperature: 4000-5000K
Connectivity
  • 2.4GHz WiFi
Storage
  • Local Storage (microSD card required)
  • Cloud
Operating Temperature
  • Camera: -5°F - 113°F (-20°C - 45°C)
  • Spotlight: 23ºF - 131ºF (-20°C - 55°C)
Weather Resistance
  • IP65 Weather resistant
  • Indoor/Outdoor
Certifications
  • FCC, IC, UL, IEC60529, California Prop 65, and IP65
Languages
  • English
Warranty
  • 1-Year
  • Wyze Cam v3 x1
  • Spotlight Kit x1
  • Quick Start Guide x1
  • Wall Mount Plate x1
  • Wall Mount Plate Tape x1
  • Screw Kit x1
  • Indoor USB Power Adapter x1
  • 6 Feet micro USB Cable x1
  • Micro USB Cable Splitter x1
Yes, you can toggle the Spotlight separately from the cam's power either manually or on a schedule using Wyze Rules.
No, the color and brightness are not customizable.
Yes, Wyze Cam v3 and the Spotlight Kit are two different parts that do not come pre-attached. But once the spotlight is attached to the camera, it may not stick again if you remove it.
Yes, the Spotlight is sold separately or as a bundle and will work with any Wyze Cam v3.
Yes, absolutely. The spotlight cam bundle is rated for indoor and outdoor use.
No, the spotlight can only be turned on by Wyze Cam v3.
By default, your spotlight will automatically turn on when motion is detected. While viewing the Live Stream, simply turn Night Vision off. A small amount of light is needed to create a clear image, but a street light outside or even a nightlight is enough. If your environment is pitch black, you can manually turn on the spotlight in the Wyze app to get a better illumination.
It's a special CMOS sensor that is very sensitive to light. This allows the Wyze Cam v3 to create an astonishingly clear image - even in extremely dark conditions.
We’ve improved the volume of the speaker so that it can be used as a siren, which is loud so you can use it to ward off intruders. Control the Siren feature from the Wyze app by using Wyze Rules.
The Wyze Cam Spotlight requires power from a micro USB cable, but connects wirelessly to the internet using 2.4GHz WiFi.
No, Wyze Cam Spotlight does not support 5GHz WiFi. It only supports 2.4GHz networks.
1080p FHD (1920x1080 Full HD).
No, The Wyze Cam Spotlight does not support the legacy Wyze Sense Bridge, as it does not have a USB-A port. It does work with Wyze Home Monitoring’s Wyze Sense Hub.
No, Wyze Cam Spotlight is powered via a micro USB cable.
20 frames per second during the day, and 15 frames per second during the night.
With a beam of light, intruders take flight.
Friends and unwanted guests alike take center stage when the light is triggered by motion, custom Rules, or schedules.
A wyze camv3 spotlight sc is attached to a house.
Lights up in any weather.
IP65 weather and dust resistance lets you place your camera anywhere to see everything inside and out.
Spotlight in app.
Spotlight in app.
WyzeCam Spotlight Bundle
WyzeCamSpotlightBundleAccordion3
A smartphone displaying a video of a person standing in front of a door.
More to love about Wyze Cam Spotlight.
Schedule your light to automatically turn on at night using Rules for better visibility, then automatically turn it back off.
Capture and view up to 3 days of continuous video with a 32 GB microSD card (sold separately).
Security features that make you go, "Wow!"
We didn’t just upgrade the look - we upgraded the whole fricken thing.
