micro sd
Step 2: Insert the microSD card into your Wyze Cam.
The slot is slightly different on each Wyze Cam. On Wyze Cam v3, it is located under a silicone flap on the bottom of the camera.
manage sd card
Step 3: Format the microSD card.
To do this, tap into your camera’s live stream from the Home tab and tap Settings > Advanced Settings > Manage MicroSD Card > Format.
Be aware that this will erase all of the existing content on the microSD card, so be sure to back up your files first.
advanced settings
Step 4: Record to the microSD card.
Tap into your camera’s live stream from the Home tab and tap Settings > Advanced Settings. Tap the toggle next to Record to MicroSD Card.
From here you can turn on local recording to your microSD Card. You can choose between Continuous and Events Only recording.
garage cam
Step 5a: View recordings from the livestream.
Tap into your camera’s live stream from the Home tab and tap the View Playback button.
Tap and drag the timeline to view recorded video from a specific point in time. You can tap the date button to select a specific date in the calendar view. The times where there is video footage available will be highlighted in color on the timeline.
Pinch and zoom on the timeline to make it easier to select a specific point in time.
playback
Step 5b: View recordings from the Events tab.
Tap on the Events tab in the Wyze app to select an event you’d like to view.
Once the Event is open, tap Playback to view the full recording from the microSD card.
FAQs
If you have additional questions, please visit our support articles regarding our microSD cards or start a chat with our team.
Save videos to a microSD card
All Wyze Cameras have a built-in microSD slot and are compatible with Wyze microSD cards. The best part is local storage is completely free to Wyze users.
You can save Wyze video recordings in two ways. 1. You can use a compatible microSD card to enable continuous local storage. 2. You could sign up for Cam Plus (or Cam Protect) to enable advanced A.I. detection, better notifications, and cloud storage.
All Cam Plus (and Cam Protect) Recorded Video Events are kept for 14 days in cloud storage and can be accessed from the convenience of a mobile device. These events can be viewed in the Events tab of the Wyze app.
It depends on what you need the Wyze camera for. While a camera that is used purely for a livestream of your pets might not need cloud storage, a security camera used for 24/7 home surveillance could benefit from videos being captured to a cloud and smarter A.I. detections.
Yes, absolutely! Wyze cameras have a built-in microSD card slot for this very reason.
